Old 01-02-2023, 02:05 PM
Phil O'Keefe Phil O'Keefe is offline
Default Control surface options with the upcoming Apple Silicon version?
Does anyone know what relatively affordable control surfaces will be compatible with the next version of Pro Tools running on Apple Silicon? It looks like things like my old Command 8 will no longer work with the upcoming non-Rosetta version of Pro Tools, so I need to look into alternatives.
Would I be able to continue to use the Command 8 if I purchase a Neyrinck plugin?
Phil O'Keefe
PT 2023.6 Ultimate (Perpetual) | Avid Carbon | M1 Max Mac Studio; 32 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
PT 2023.6 Studio (Perpetual) | M1 MacBook Air; 16 GB RAM / 1 TB SSD, macOS 13.4.1 Ventura.
Old 01-02-2023, 02:11 PM
Default Re: Control surface options with the upcoming Apple Silicon version?
I suspect only new thing that really makes sense is the S1 and Dock unless you want to go to the less capability of HUI.
Edit:
Would I be able to continue to use the Command 8 f I purchase a Neyrinck plugin?
It's not so much a plugin it's the Neyrinck V-Control app.
Yes, check with them, I believe they have Apple Silicon support for the Command 8 already.
Old 01-03-2023, 06:31 AM
Gemylon's Avatar
Gemylon Gemylon is offline
I am quite sure Neyrinck will come up with a solution.
I know they are working on support for C|24 (talked to them),
so the Command 8 support is probably in the same process.
MacBook Pro M2 Max / Pro Tools 2024.3.1 / MetricHalo ULN-8 MKIV / AVID Console C|24 / UA 6176 / Neumann U67 / Oram S200 / UAD Octos /
Old 01-03-2023, 07:35 PM
Thanks, guys. I think I’ll reach out to Neyrinck and see what they have to say, and then go from there.
Phil O'Keefe
Old 01-03-2023, 10:59 PM
David McCarthy David McCarthy is offline
Great to hear about Neyrinck/C|24/Silicon. My heart sank when I learned they were no longer supported.
Old 01-04-2023, 06:06 AM
James Steele's Avatar
James Steele James Steele is offline
Well, believe it or not, the old Artist Control and Artist Mix still work well. I actually have a Euphonix MC Control and MC Mix that I paid $600 for BOTH used and both are updated with latest Avid firmware and work fine... even with the latest 2022.12 public beta running native on my Mac Studio.
Old 01-10-2023, 05:51 PM
SKI's Avatar
SKI SKI is offline
I still have my Command 8 and while it has served me well with no issues I would have a hard time investing time or money into using it.
I would say if you don't mind the investment it may be a good time to switch to a Eucon based controller.
Eucon is just a whole different game all around.
URBAN MUSIC-
(Hip Hop and R&B)
Old 01-10-2023, 07:46 PM
Eric Lambert's Avatar
I hope Neyrinck has us covered but if not the S1 has been a solid option for me and a couple guys in my company. I came from large format consoles then down to a ProControl then to a wide Avid Artist config and finally to the S1 (with accompanying iPad expansions) and it's still comfortable and works rather well.
Old 01-11-2023, 12:32 AM
Ben Jenssen's Avatar
I confirm, Artist Mix works on 22.12 apple silicon beta.
I'm so happy that I won't have to add an application like Neyrink or Soundflow to my system to have things work, also not have to pay for something that might even get in the way and waste my time. Artist Mix will fit my needs for many years more.
Old 01-11-2023, 06:32 PM
hurdy gurdy hurdy gurdy is offline
No doubt. Like mentioned I'm also of the opinion that the deep integration of Eucon control and those surfaces with PT is the way to go if into using PT heavily.
Len
Waves v14 for upcoming PT Apple Silicon Native info swethington AAX Plug-ins 13 11-18-2022 03:16 AM
NAMM: New control surface options nst7 General Discussion 65 02-05-2014 04:57 AM
iPad Control Surface Options Loopagator macOS 15 05-09-2013 07:24 PM
Control surface options for PT mixer James Drake Pro Tools TDM Systems (Mac) 1 10-16-2011 07:03 AM
control surface options for PTLE and digi 001... agentCB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-11-2002 06:10 AM
