XPAND2: Separating the Toms from the Cymbals
In XPAND2's basic drum kits, is it possible to separate the cymbals from the toms to separate tracks? The kick and the snare are easy, but some of the cymbals and toms share the same range, for example (hats+toms+cymbals selector). I want to isolate ALL the toms on one track and ALL the cymbals on another track and wonder if XPAND2 has this capability. PLEASE tell me that it does. :O) Thanks in advance.
Re: XPAND2: Separating the Toms from the Cymbals
Put the plug-in on an aux track and trigger it from separate midi tracks - one for each part.
When you're ready to commit to audio simply mute unwanted parts and record to a separate track. Repeat for each part. |
Or you could record the MIDI with a single MIDI track, then duplicate the MIDI track so you have one for each drum part and remove the MIDI notes on each track so that each has a single instrument. Create the same number of Xpand instrument tracks and setup each MIDI and Instrument track to its own MIDI channel. Then they are separated, though you need a fast enough computer if you have a ton of Xpand tracks. This way you can bounce them all down to individual audio tracks in one pass. I used to do this all the time for drums with Xpand and Colossus.
Chris
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
"XPAND2.big" Xpand2 Can't Finde The Factory Content?? | toolgirl | macOS | 1 | 02-29-2012 08:04 PM |
Are toms recorded 1 track to 1 piece, or all toms on 1 track? | rockguitarist1255 | Pro Tools 10 | 8 | 02-17-2012 09:27 AM |
cymbals cut off in BFD | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-21-2006 01:55 PM |
Hi-Hat and Cymbals | torquemada | Tips & Tricks | 5 | 05-28-2006 11:58 PM |
BFD cymbals cut off | billya | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-06-2006 07:42 PM |
