Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 01-20-2013, 02:24 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default G5 case mod - Hackintosh
Since most of the new Mac's are lackintosh's I decided to make my own - I have finished modding my case - almost -
Gigabyte GA-X79-UD5
i7-3930K
Samsung 840 Pro 128GB
16GB corsair veng. 1800 MHz
Evga GT - 640
Corsair CX600 pwr supply
Daniel
Old 01-20-2013, 02:28 PM
YYR123's Avatar
Currently mounting my cooler - I think I will have to take the mobo out again
I got the mobo panel and back plate from Mountian Mods - If you're going on modify a G5 case you have to make sure in order the 2 x 80 backplate
Daniel
Old 01-20-2013, 07:16 PM
sunburst79 sunburst79 is offline
Default Re: G5 case mod - Hackintosh
Didn't know mountain mods had that type of stuff. I just used a Lain Li VC1000 when I built my tower in 2005. Still running strong 8 years later. I did flip the PSU over and cut a 120mm hole in the top of the divider. This let me turn the fan way down on the enormous Zalman Copper CPU fan.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-20-2013, 07:26 PM
YYR123's Avatar
Cool stuff I liked mine - nice quality and good fit
Daniel
Old 01-21-2013, 07:14 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Nice work!
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 01-21-2013, 08:21 AM
Originally Posted by John_Toolbox View Post
Nice work!
Coming from the original mad macmodder thats quite a compliment
Scott
Core 2 Specs Page
Old 01-21-2013, 08:35 AM
Yeah, this thread reminds me of my old mdd g4 with the temp readout....
I've actually been toying with another idea for a crazy mac project... not sure if I'm going to do it or not though... still have a lot of other things that are probably more important to work on.
- John
Old 01-21-2013, 08:50 AM
My stuff is usual geared toward looking industrial in side. After owning a few HIWATTS you will never run wiring the same afterwords. My current DAW was the first time I ever sleeved nearly everything. Happy with the way it came out.
Scott
Core 2 Specs Page
Old 01-21-2013, 09:48 AM
Interesting. A quick google search for hiwatts wiring reminds me a lot of the industrial control panels I used to wire. Everything was bundled and bent neatly, and even though it was just buttons that controlled relays, the wiring was way oversized so that it could handle the vibration and abuse it would take in an industrial setting.
- John
Old 01-21-2013, 10:21 AM
YYR123's Avatar
Yes I'm going to wire tye everything nice and neat once it's up and running but I need to mount a few more things before I make everything final
But still even though I do my best job I know it won't look anything like the G5 that I took apart
That thing was beautifully put together No extra wire slack anywhere
Daniel
racks in general... shock or case-in-case xcx VENUE Live Sound Systems 1 05-31-2013 04:13 PM
Hackintosh - H67 & i5 2500K ? JazzyJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-01-2012 04:49 AM
Hackintosh on my rig? Raoul23 Pro Tools TDM Systems (Win) 7 07-01-2011 03:26 PM
Ultimate Hackintosh case? Craig F General Discussion 13 04-14-2011 03:43 AM
Hackintosh Help HDK_Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-16-2010 10:45 AM
