popping/static during playback. Here is Sandra report. Please help!
Here is my Sandra report. I have seen several other threads about similar problems with static and popping while playing back and I have tried many, many things. Please help! Thank you!
-Josh SiSoftware Sandra Computer Model : Toshiba Satellite A665 Workgroup : WORKGROUP Host Name : owner-PC User : owner Processor Model : Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz Speed : 1.86GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 6MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Toshiba NWQAA BIOS : Toshiba 1.80 09/14/10 Bus(es) : PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DDR3 SO-DIMM Chipset Model : Intel Core (Clarksfield/Lynnfield) DMI Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Intel Core Mobile (Clarksfield) UnCore Front Side Bus Speed : 2x 2.13GHz (4.26GHz) Total Memory : 4GB DDR3 SO-DIMM Channels : 2 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : Samsung M471B5673FH0-CF8 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Samsung M471B5673FH0-CF8 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : NVIDIA GeForce 310M (16 SM4.1 1.47GHz, 512MB DDR3 1.58GHz 128-bit, PCIe 2.00 x16) Graphics Processor Compute Shader Processor : NVIDIA GeForce 310M (16SP 1.47GHz, 512MB DDR3 1.58GHz 128-bit) Storage Devices TOSHIBA MK6465GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 596GB (C:) SAMSUNG HN-M500MBB (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) : 466GB (E:) Hitachi HTS725050A9A364 (500.1GB, USB2/SATA300, 2.5", 7200rpm, 15MB Cache) : 466GB (F:) Optiarc DVD RW AD-7703S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices New Volume (E:) : 466GB (NTFS) @ SAMSUNG HN-M500MBB (500.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) LaCie (F:) : 466GB (NTFS) @ Hitachi HTS725050A9A364 (500.1GB, USB2/SATA300, 2.5", 7200rpm, 15MB Cache) TI106042W0A (C:) : 583GB (NTFS) @ TOSHIBA MK6465GSX (640.1GB, SATA300, 2.5", 5400rpm, 8MB Cache) System : 1GB (NTFS) Hard Disk (Q:) : N/A Optical Drive (D:) : N/A @ Optiarc DVD RW AD-7703S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Toshiba HM55 LPC Interface Controller Audio Device : Toshiba P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Audio Device : Toshiba High Definition Audio Controller Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Audio Codec : nVidia 000Bh Disk Controller : Toshiba P55/PM55/3400 4 port SATA AHCI Controller USB Controller 1 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Deskjet F4100 series (600x600, Parallel, Colour) Printer : HP Deskjet F4100 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon Inkjet SELPHY DS700 (600x600, Parallel, Colour) Printer : Canon Inkjet iP2600 series (600x600, USB, Colour) Printer : Canon Inkjet iP2600 series (600x600, Parallel, Colour) Network Services Network Adapter : Realtek PCIe FE Family Controller (Ethernet, 100Mbps) Network Adapter : Intel(R) Centrino(R) WiMAX 6250 (Ethernet) Wireless Adapter : Intel(R) Centrino(R) Advanced-N 6250 AGN Power Management Battery No 1 : Toshiba Smart Battery Lithium-Ion 0.01Wh/3.33Ah Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.8 |
Re: popping/static during playback. Here is Sandra report. Please help!
I also have this same problem while I'm trying to record. This is preventing me from getting any work done. Any tips will be appreciated. I'm not super computer savvy, so be patient with me! haha
Is there any other information I can provide that might help? I want to get back to work on my rig! Everything was fine until I switched laptops and operating systems. I'm using a Toshiba Satellite A665 with Windows 7...
-Josh |
I may have this wrong, but is drive f your audio drive? If so, is it connected via USB? That could be a problem.. Also it looks like your system drive (c) is running at 5400rpm...
Make sure to disable onboard audio etc.. |
With Windows 7, USB2 is actually preferred now(due to 7 having better USB drivers). 5400 rpm is too slow for recording, but should not be an issue as a system drive(with a proper recording drive). As asked, which drive are your sessions on? Is this a laptop? Have you disabled wifi and networking when running PT? Have you done all the system tweaks? What interface and what exact version of PT?
The drive I'm saving my sessions on is actually E: and it is connected via eSATA.
How would I go about disabling "onboard audio"? Yes, my computer is a Toshiba Satellite A665 laptop. I have tried disabling wifi and networking. I'm not certain what all "system tweaks" you're referring to. I am using Mbox2 with Pro Tools 8.0.3 LE. I really appreciate you guys trying to help! Please forgive my minimal knowledge! Thank you! |
Windows>Control Panel>Device Manager>Sound, Video and Game Controllers>Double click each controller (other than anything showing up as Mbox)one at a time, Driver Tab>Disable. Try this but I'd be surprised if it makes any difference. If it doesn't just re-enable them if you want.
I would be inclined to update (free) to v8.05; http://avid.custkb.com/avid/app/self...p?DocId=393667 This is an updater only so do not uninstall current version, just run updater. Then: Make sure you have latest Mbox driver; http://avid.custkb.com/avid/app/self...3=1450&Hilite= Install driver with Mbox turned off then reboot with it switched on. Then: In pro Tools>Setup>Hardware>Make sure mbox clock source is set to 'internal' Then: Report back on whether or not that has made any difference
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Bob |
@zedhed: I appreciate your tips! I did everything that you suggested and I'm still having the same exact problem. Is there anything else I can try? I'm desperate for a solution! This is a huge inconvenience and everything was working just fine until I switched over to this new laptop with Windows 7! Thank you again!
@Bob: I had the same setup (5400 rpm drive with 8 mb cache) when I had my previous system and I never had a single issue with anything. This is the first problem I've encountered. And the problem is a HUGE one! Again, I sincerely appreciate any further help! -Josh |
You may have been lucky!!! Definately get a 7200 RPM drive and also do ALL Avid recommended system tweaks. Make sure ALL your plugs are up to date. Seems like a lot of fussing around, but once you do ALL these things, you will be good to go.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Sandra report | mickeyrouse | Getting Started | 3 | 01-13-2014 05:57 PM |
Pro tools 9 choppy playback sandra report included | daniel101 | Pro Tools 9 | 1 | 06-11-2011 11:58 PM |
Static / crackling when record-enabling (w/ Sandra report) | scadh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 11-09-2010 09:00 AM |
Thanks! Sandra Report | stevegrisham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-08-2009 09:26 AM |
My Sandra - make suggestions. Have some popping. | shultzee13 | Pro Tools M-Powered (Win) | 0 | 06-21-2009 07:19 PM |
