96K 5.1 interleaved .wav problem
I am having a strange problem when bouncing out a 5.1 interleaved 24bit 96k file. After the bounce is complete, there is no file to be found. The data availability in the disk is as if nothing was ever written. I can even go to the Terminal and look in the directory and nothing is there, nothing hidden or strange.
Any thoughts? I am sure there is a simple fix for this, its late... G4 1.25 PT 7.2cs3 HD2 192io |
Re: 96K 5.1 interleaved .wav problem
Is your audio very long? A BWAV in PT can only be 2GB (although BWAV supports 4GB and more if it´s a RIFF64).
2GB is already reached after 20 Minutes. Maybe that´s the cause? If it´s a split-file it can be an hour because each channel can cary 2GB. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
On the 2gb file size issue. .
I've had this problem before when recording. . But when the 2 gb limit is reached PT just drops out. . . The file IS there on the drive but doesn't appear in the edit window. . When bouncing to disk the result may be different. . ? Sorry I don't have a difinitive solution. Good luck.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
There´s no way to have an interleaved file in a PT session unless you re-import it and have PT convert it to a split file again. Frank.
AH, I see. I had no idea about the 2 GB limit. I am sure thats it. The file should be somewhere around 2.3GB if all together, I am splitting it up right now.
Once again, the DUC comes through. Much thanks to all of you! |
export MP3 interleaved | Marvin the android | macOS | 4 | 02-01-2014 08:41 AM |
Interleaved uses more resources? | Frank Kruse | Post - Surround - Video | 15 | 07-15-2012 09:47 AM |
Can i stay interleaved? | Nathan Schock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-23-2008 04:20 PM |
5.1 bouncing to interleaved .wav | Evil Jack | Post - Surround - Video | 3 | 05-05-2005 11:15 AM |
SD2 interleaved and Jam | polyorchid | Pro Tools TDM Systems (Mac) | 2 | 07-12-2001 04:45 AM |
