Old 07-08-2004, 02:57 AM
ISedlacek ISedlacek is offline
Default ASIO drivers in another host application ?
I used to use PTLE, now I work in Samplitude. I still have Digi 002 and want to use for mobile recordings with laptop and Samplitude. I installed the software (PTLE 6.1) and ASIO drivers. I can find Digidesign ASIO drivers 1-8 appearing in Samplitude, but these obviously refer to analog inputs in Digi 002. I am using my own preamp and AD and want to use Digi 002 just as digital input (SPDIF), which works in ProTools but I cannot make it working in Samplitude. WHere is the Digidesign ASIO driver which would refer to SPDIF in/ out ? Thanks for an advice.
Old 07-08-2004, 04:54 AM
da BaSsTaRd! da BaSsTaRd! is offline
Default Re: ASIO drivers in another host application ?
the asio driver works for all i/o. i get all i/o in cubase. maybe its a samplitude problem?
i love my apple iPhone!
Old 07-08-2004, 08:31 AM
lemix's Avatar
lemix lemix is offline
ISedlacek
In Samplitude, where you choose the "audio card" setup ..
Once the ASIO is selected, look for "advanced" or "more" . That will take you to setup.
Here you'll be able to select the optical port...
good luck,
cheers,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 07-08-2004, 02:46 PM
Thanks. All the I/Os suddenly appeared there after 2 restarts. It is recording BUT I get about 50 errors within 10 minutes of recording: "Lost ASIO Buffer". What could be the problem ?? Using Laptop Acer Aspire , Pentium Centrino 1,6, 512 MB RAM + Digi 002 Rack.
MC-Mix Not zeroing out with host application mixer "Digital Performer 7.2.3 SB MIX Artist Series 1 07-07-2011 08:48 AM
Has anyone tried the ASIO drivers with a 002? vonbleak101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-24-2002 11:58 PM
Help on ASIO Drivers Jeffrey Yue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-06-2002 07:53 AM
ASIO drivers for PC!!!!! QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 05-11-2002 05:17 AM
M-Box Asio drivers? JROB6716 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-31-2002 06:28 AM
