#41
Re: DANTE and HDX card Max I/O
But on the other hand, LUCKILY it's there, so that also with a non-Avid-branded product , so any thinkable interface including an Apollo, you can just measure your HW insert delay manually once and be done. So that you'll have sample accurate HW insert delay compensation with any brand audio interface possible. EDIT: imagine patching an outboard device with an AES/EBU send and return, Pro Tools nor a MTRX could ever possibly know the number of sample delay added with the external devices conversion latency. So again then, luckily it's there to just measure once and fill in manually (at a few sample rates you work on) and have a solid sample accurate HW insert patch.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3 |
#42
Once for each sample rate, and then you have to remember to use the correct I/O settings each time, which is easy to miss. Less of an issue for post I suppose, but for music I'm frequently working at all four common sample rates.
https://lukehoward.com/ |
#43
It's annoying. I know. But as long as I have a MTRX I didn't find it much of a problem. Still mix about everything music in 48khz so when I want to patch a location recording through my Shelford channels back in the studio my HW insert is just set at 1.00 ms for AD>DA and it's working all fine:)
#44
just thinking out loud, an exported I/O setup template in pro tools, if I'm right, also contains the HW Insert delay numbers. So for the heavy outboard-patchers out there, wouldn't it be smart to measure once, and save your whole I/O template as an MTRX48.pio till MTRX192.pio file. Then only load or import your I/O setup profile for the corresponding sample rate and be done in one click:)
#45
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
#46
In fact, I was told—sounds like my question maybe wasn't fully understood—that there aren't really proper HW inserts in DADman, which is true when you restrict it to DADman only. But I mentioned I'd be using it with Pro Tools, to which he made no mention of still being able to use the INSERTS tab in Pro Tools itself and manually enter latency, by which you can then use PT HW inserts like you always did. But you guys have just confirmed that all that is possible. So that's a relief.
#47
Right, there aren't hardware inserts in DADman, and actually that is something that could be useful (for example, for integrating external speaker processing whilst using the MTRX converters).
FS: Dante VIA and Dante Virtual Sound Card | henningaround | Buy & Sell | 0 | 12-29-2021 02:04 AM |
MTRX Dante 128 Card Error | MarkH | Pro Tools | MTRX & MTRX Studio | 10 | 08-20-2021 05:42 AM |
WTB Dante card for Behringer x-32 | dwx1958 | Buy & Sell | 1 | 01-08-2021 02:17 PM |
Can't get MTRX Dante card to work... | SomeOtherGuy | Pro Tools | MTRX & MTRX Studio | 25 | 01-22-2020 10:53 PM |
S3 and Dante Virtual Sound card? | Tim R. | Avid S1, S3, Dock and Control App | 2 | 12-11-2017 05:05 PM |
