  #61
Old 03-07-2023, 02:18 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: Mac Ventura Compatibility
Originally Posted by Eric Lambert View Post
I just had to look past the spastic redraws.
What a great line for song....Or maybe even a Punk Band name "The Spastic Redraws"
System :
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4
Enjoy the Journey
.... Kev...
  #62
Old 05-21-2023, 06:58 AM
EdoFede EdoFede is offline
Originally Posted by ZWaves View Post
Yes, The Dolby Atmos Renderer works with no problem on its own on macOS Ventura. The problem arises when you have to use Dolby Audio Bridge to interconnect from another application... No signal is being passed.
Same problem on:
- macOs Ventura 13.4 (22F66)
- Dolby Atmos Renderer 5.0.0_272-501207d3
- Pro Tools 2023.03
Both Dolby Renderer and Pro Tools does not show the "microphone access request" popup, which give the ability to get audio from audio devices.
The apps are not even listed in the OS Security panel under Microphone page.
I solved by manually inserting both apps in the authorisation DB.
1) Quit both apps
2) Open Terminal
3) Paste below commands, one line at time
4) Check for errors in command line
5) Start apps and verify
Code:
cp ~/Library/Application\ Support/com.apple.TCC/TCC.db ~/TCC.db.bak
sqlite3 ~/Library/Application\ Support/com.apple.TCC/TCC.db
insert into access values ('kTCCServiceMicrophone','com.dolby.atmos.renderer', 0, 2, 2, 1, null, null, null, 'UNUSED', null, null, 1669648527);
insert into access values ('kTCCServiceMicrophone','com.avid.ProTools', 0, 2, 2, 1, null, null, null, 'UNUSED', null, null, 1669648527);
.quit
In case of problems, to restore the old DB:
Code:
cp ~/Library/Application\ Support/com.apple.TCC/TCC.db ~/TCC.db.problems
rm ~/Library/Application\ Support/com.apple.TCC/TCC.db
mv ~/TCC.db.bak ~/Library/Application\ Support/com.apple.TCC/TCC.db
Bye,
Edoardo
macOS Ventura 13.0 - Anyone tried it (or a beta)? alzakent Pro Tools 50 05-19-2023 06:31 AM
Pro Tools Compatibility with macOS 13 Ventura newcens Pro Tools 14 02-08-2023 01:18 PM
MacOS Ventura LDS macOS 7 09-15-2022 02:30 PM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 2 11-17-2010 11:05 AM
AMD 64 compatibility with PT 6.7 JasonGough 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 03-16-2005 03:56 AM
