Re: Importing 5.1 mov files into ProTools 10
Snow Leopard comes with both QT 10 and 7.
export -> audio -> AIFF -> options -> channels -> 6 channels
I updated from L to SL and there is no QT 7 on this system. Separate install somewhere?
You'll have to extract the audio tracks one by one.
With Apple-J you open the properties window, showing all tracks in the movie. Deselect all but the first audio track, click extract. A new QT movie will open; Apple-E opens its export dialog. Select Sound to wav, Mono, etc and save. Then deselect this track in the props window, select next one, and so on. Track order of the six mono files could be either film or SMPTE Cheers Florian |
Check into Utilities folder.
#16
Just the other day I downloaded a 1080p QT with 5.1+LtRt attached from a Distributor. I imported the QT, then I went to import audio, and selected the QT. Pro Tools told me there were 8 tracks, well I should hope so! I imported them just fine. These were 24/48k files by the way. Tschüss, Tom
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
#17
http://support.apple.com/kb/HT3678
#18
I tried this method however it didnt work. Instead it converted the 5.1 file to a mono file. It did not isolate each file. Did i do somethign wrong or is there a program that will read the H.264, 1920 x 800, Millions AAC, 5.1 (C L R Ls Rs LFE), 48.000 kHz file?
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0 |
#19
That's why I suggested the tedious one-by-one method. Works for me (but I'm talking about linear PCM; maybe its no-go with AAC). Cheers Florian |
Problems importing old ProTools files | themadwizard | Pro Tools 10 | 4 | 03-21-2012 10:30 AM |
Importing midi files into ProTools 8 | memmms | MIDI | 10 | 05-06-2011 07:50 AM |
Importing midi files into ProTools 8 | memmms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-27-2009 01:54 PM |
Importing .syx files into ProTools | rastro2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-24-2005 06:53 PM |
Importing Sonar files to ProTools LE | EarthGuest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-17-2005 05:34 PM |
