Re: After all these years.. still crackling and popping when moving windows.
Again, I say to the OP - why not just use the Mac version of Pro Tools??
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Because his Mini has Mavericks and he's running PT10. I believe you can backdate Mini's to Mountain Lion as I think the only Macs that absolutely, positively have to have Mavericks are the iTrashcans. That would be the simplest and he could run the Mac version of PT.
i am pretty shure it is not software-related , sounds for me like a ground-problem with the firewire-port...
maybe a 6pin on 4pin and vice-versa firewire-adapter could help , in this case your interface could not be buspowered via FW (if it is?) but the cpu-noise should be gone. You would need then a seperate power-adapter for your interface if it is buspowered via FW had a similar issue in the past with a Motu FW interface and the configuration above hepled.
foley artist , soundeditor |
I still don't understand why you don't just install PT10 on the current Mavericks partition and see how it works? Far simpler than mucking about with backdating the OS and all that nonsense, and it would quickly prove whether or not virtualization is the problem. No, it's not officially qualified, but it's working fine on loads of Mavericks systems out there.
best, rich
The reason the poster is running PT10 in Windoze is because his Mac Mini came with Mavericks and PT10 isn't supported in Mavericks. Last edited by musicman691; 06-25-2014 at 03:33 AM. Reason: wrong info rferred to |
But as a troubleshooting exercise, installing PT10 on Mavs will take 15 minutes and would put to bed the OS-or-not OS question. Don't understand why the OP wouldn't just do it? best, rich
I don't understand it either. Heck the download will take longer than the install; maybe 15 minutes at that all told download to finished install.
Last edited by musicman691; 06-25-2014 at 03:34 AM. Reason: referred to incorrect info |
Crackling when moving windows?? | the19thbear | Windows | 34 | 12-20-2011 07:42 AM |
LE 8.0.4 phantom popping, crackling. | 809578998 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-29-2011 08:33 PM |
Popping and crackling | sinnagod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2004 07:03 PM |
low output noise & crackling fuzz static on outputs after years of no problems | M-Link | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-14-2003 12:38 AM |
Need Help! Popping and Crackling Sounds!! | Chris LoA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-07-2001 01:40 AM |
