Artist Control dog slow
I am setting up a Mac mini test system before getting my New Mac Pro. Been reading all the problems with the artist series and wanted to add an issue I am experiencing.
I have two artist mix, a transport and an artist control, connected through an Ethernet hub to the Mac Mini. On Mavericks and PT 11.1, with Eucon 3.1. I followed the various guides on this forum and finally got the units to connect. At first it all works ok, but if I start using the soft keys on the control unit they start becoming unresponsive and stop responding. They seem to buffer in that they do start doing whatever I pressed but after an indeterminate time lag. This is a new bug to me and makes the units really barely usable. I know JC is very responsive and see the efforts he is making to get to the bottom of these issues but would love to know if we are close to a resolution or still trying to find root cause. Thanks |
Re: Artist Control dog slow
Go to your Eucon app and click "Prevent App Nap" check box. I don't know why Avid doesn't post this on the forum but this will fix your issue when running on Mavericks.
Thanks - but I cannot see that check box anywhere in Eucontrol 3.1 on a Mac. Where is that hiding?
Google is your friend... http://reviews.cnet.com/8301-13727_7...s-x-mavericks/ |
Many thanks
I'm dealing with the same issue. I have the current update for Pro Tools 11.1.2 and have update EuControl to 3.1.2 (which is supposed to kill the App Nap bug) on OS Mavericks.
My dilemma is that 3 days ago I was running Pro Tools 10 on Mac OS X 10.8 and EuControl 2.6 with absolutely NO ISSUES. I finally decided to upgrade my OS and Pro Tools and EuControl software and this happens. I can not say that it a Apple issue or Avid issue because were updated at the same time. PLEASE HELP! Thanks. |
If that is not it then it's not the same underlying issue (it might be similar symptoms). |
Dear ATL Sound...
On Maverick with ProTools 11.1.2 and with Eucon 3.1.2... I had many problem with very slow fader response. Brian from Avid support knew the problem and found a tweak. You need to use Eucon 3.1 instead of 3.1.2, You need to follow this procedure... already described on this forum. see: http://duc.avid.com/showthread.php?t...ighlight=Brian After that, my 3 Artist surface controller became very snappy ! Regards
iMAC i5 with 32Gb of ram and Promise J4+SSD Sibelius Ultimate running PLAY using SO Plat+, SC_VOTA, HS Dia, RA, Silk, QLSV Pro Tools HD Ultimate & Prism Lyra2 |
Avid Artist Mix Slow to Update Display | wuwmstudioc | Artist Series | 4 | 11-22-2013 08:31 AM |
How to control plugins applied to audio files with Artist Control | ozu | Artist Series | 3 | 04-01-2013 02:36 AM |
Touching Artist Transport Freezes Up Artist Control in Logic | sonofmack | Artist Series | 1 | 03-13-2013 08:22 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Using Artist Control with Artist Transport? | GrievousAngel | Windows | 2 | 03-14-2012 03:29 PM |
