#21
Re: Pops noise after quick punch. Pics included.
This is a problem with QP itself. I don't have this problem in 9 but did have it in 8.04. When you use QP it starts recording as soon as you hit play. If you have a 2 bar pre roll and a 2 bar post roll the problem will occur where the region begins, not where the recording begins. I hope I don't run into this in 9! I had a whole day of pencil tool fun with that one!
Sign up for all things....AWESOME! Kris May the music move you |
#22
Ive tried with my rosetta 800 hooked to my 002 via adat and then unhooked that and tried with just my digi002 and its the same on both.
Click here for delay compensation |
#23
Well no.. method isn't irrelevant because a lot of peeps get pops from just hitting stop instead of stopping the recording pass then stopping it...
I get sessions from people all the time like that where I then hav to clean up there mishap... that is why I asked about the method...
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
#24
#25
Is this just in Windows? I couldn't duplicate the probem on PT M-Powered 8.0.4 on Mac OS 10.6.5. The discontinuity is right at the region mark (not delayed) and a quick punch crossfade value other than zero creates the desired ramp eliminating the pop.
Kevin Windrem Sweet Spot Sound |
#26
Well it all started for me with the Windows 7 64 bit upgrade.
#27
Sorry. I mean, if the converter passes a given string of bit values to the program, it had darn well better write that string to disc without changing it in any way for the entire time that you're in record.
I'm shocked that a tool like PT would do otherwise. Seeing now that this has been a known issue for several weeks, I'm surprised there hasn't been a full-voice chorus of protest. Maybe it doesn't affect very many users? Maybe everyone was so busy complaining about the other major issues in 8.x that we hadn't got around to this issue yet? If you can't trust an audio recording program to record properly, what can you trust it to do? This is worse than the old play-pause plague and the improper placement issue put together.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
#28
Oh, I see what you mean. I only meant that a different method of punching in and out shouldn't change the waveform within the recorded area, which is what's happening here. It looks like PT is writing zeros at the punch point even when using Quickpunch. That's heart-attack material for me.
#29
#30
I upgraded to Win7 64 and PT9 the other day and things are kind of smooth, havent had any issues other than me not reading this forum in advance and finding out that you should always run PT as administrator and such. Anyways, played something up today and whenever i hit pause (space) i hear a cracle/distorsionsound. When i hit play i dont remember but i think it´s there also. The only thing i can think of is that i have enabled AHCI for my HDD´s in the BIOS. The session was recorded on PT 8.0.1 with the 8.0.4 audiodrivers. Other than that, i have made no rearrangements of my computers BIOS or settings than i had on XP 32 bit with PT 8.0.1.
PC 7980XE @ 4.2 PT 12.7 Ableton 10.0.1 Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650 IS Pro Double 6" Speakers, www.intelligentsound.se/ |
Quick punch crack and pops update | jeam25 | Windows | 2 | 09-24-2011 07:44 AM |
routing question pics included | psychoth | macOS | 3 | 02-15-2011 02:32 PM |
Pops on every quick punch in 8.0.4 | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 10-05-2010 09:44 PM |
Quick punch problem creates pops. | Final Score | Pro Tools TDM Systems (Mac) | 0 | 09-07-2010 10:40 AM |
CLick noise when i quick punch | toofly4asoundguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-01-2004 03:17 PM |
