Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #201
Old 10-10-2020, 04:46 PM
uptheoctave uptheoctave is offline
Default Re: First steps with MTRX Studio
Originally Posted by Goombot View Post
My switch is an HP 1920 which I was told is Dante compatible. Either way, during all this I took my switch out of the loop and just plugged the Mac into the extreme and the MTRX into the Mac and it didn't work so it's not the switch unfortunately. Someone mentioned to me that the Mac Pro 10 gig ethernet ports are not compatible with Dante. I'm not sure if that is true. Either way, how come when I plug my thunderbolt to ethernet into my Mac and get internet the DVS doesn't see an IP? Ugh
You have to stop conflating issues- you have several things going on.
As I've said twice there us an issue using DVS via internal ethernet ports.
It isn't that the ports are not compatible but there is an issue with internal ethernet ports working at the moment.
Audinate will fix the issue eventually.
You will have to use an adapter for DVS if you want to use DVS.
Also, have you disabled EEE on the switch?
Is IGMP snooping on or off?
Show me screenshots of DVS using an adapter.
You have to select the correct network interface in DVS.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
  #202
Old 10-10-2020, 04:49 PM
Goombot Goombot is offline
ok give me one second. thank you
  #203
Old 10-10-2020, 04:51 PM
Here you go.
File Type: jpg Screen Shot 2020-10-10 at 4.51.21 PM.jpg (37.1 KB, 0 views)
  #204
Old 10-10-2020, 04:54 PM
And I just changed the MTRX to a static IP. I can change it back but the adaptor didn't see the DVS card either way.
  #205
Old 10-10-2020, 05:02 PM
Here you go.
Too low resolution, can’t read it.
James Richmond
Affiliate Links:
  #206
Old 10-10-2020, 05:03 PM
Why did you do that?
James Richmond
Affiliate Links:
  #207
Old 10-10-2020, 05:04 PM
Sorry I'm not sure what you mean. The resolution is fine on my end. I'll upload again and see if something changed
  #208
Old 10-10-2020, 05:08 PM
I did that because I’m trying anything I can. Again, it didn’t either way.
  #209
Old 10-11-2020, 01:48 AM
Firstly stop doing that.
Imagine you are a doctor and your network is a patient.
Do you chop of its leg or give it a haircut to see if it fixes its liver complaint?
No.
Do things you need to, when you understand how the network works.
Hacking away at it like this is why you are in this position and it makes it harder for anyone troubleshooting your issue.
I don't mean to be harsh here- but this is the truth.
Res is too low: this is what I see:
James Richmond
Affiliate Links:
  #210
Old 01-01-2021, 02:01 PM
Sparemonkey Sparemonkey is offline
Originally Posted by creativecontrol View Post
I don't believe you have the correct delay value assigned for the HW Insert Delay in IO Setup. Looking at my notes - at 48kHz with AD DA patched into Pro Tools you should be ~ 1.17 ms. I can take a look at this later today and repro.
Jeff
The delay compensation doesnt work at all with the unit. Will this be fixed anytime soon? Why isn't this top priority with Avid?
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
Still no specs on MTRX Studio Avid? corp Pro Tools | MTRX & MTRX Studio 51 04-02-2020 05:31 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
analog console, next steps for my studio badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2003 08:03 AM
