Re: Still no solution for Analog Summing delay compensation
If it would be possible for negative values on an auxtrack, avid would have invented time travel. fluxcompensated.
Scott Gatteño |
Please do post your workaround, I‘d be highly interested!
My main issue is that mix stems are not on the grid, which makes collaboration a pain. Being able to do consistent master rides would be really nice too! Right now I just align and offset by ear, which is a hack job of course. |
Oh wow, there's a solution to this??
I don't think there is or the op would have posted it already. Or he found it doesn't work like he thought it would.
If we had an audio track implementation like we do for MIDI with "Real-Time Properties" allowing a negative delay while showing elements still snapped to the grid it would be great. (see attached jpg).
It would essentially need to buffer playback for those selected tracks by whatever your desired hardware delay compensation settings are, which is really no big deal in terms of waiting for Pro Tools transport to start. It might make looping a playback range a little difficult to implement smoothly, but I'm sure our friendly programmers at Avid can pull this off. |
Is this so difficult too understand. In a modern Mixsituation many mixers mix into the masterbus processing. and a part of this is digital after the analog summing :) and I think it's obvious that the mix should be on the grid for correct automation. |
and I will explain it the next days. but I am extreme busy at the moment, my english is not perfect for explaining technicals things very fast, so I need a little bit time to do this right. Frank |
Analog Latency and Delay Compensation | wedge | Pro Tools HDX & HD Native Systems (Mac) | 9 | 12-23-2011 12:15 PM |
Finally a Solution for Plug-in Delay Compensation!!!!!! | Sonic Nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-10-2008 09:00 AM |
Analog insert Delay Compensation | midnightsun | Pro Tools TDM Systems (Mac) | 7 | 02-16-2008 10:32 AM |
Delay Compensation Solution in M-Powered? | fabriciom | Pro Tools M-Powered (Win) | 4 | 01-08-2007 06:27 PM |
What's the summing solution for mixing ITB? | Jon_Atkinson | Pro Tools TDM Systems (Mac) | 16 | 05-25-2005 11:01 AM |
