Old 02-23-2012, 09:23 PM
anth anth is offline
Default eleven rack reamp question
Is it possible to reamp and bypass the eleven rack sounds i.e. reamp into a guitar combo with just the di signal like a normal reamp box would do?
I have the mbox 3 atm and I'm not sure if this allows me to reamp due to limited I/O...?
Old 02-24-2012, 05:59 AM
Muzza_Boogie Muzza_Boogie is offline
Default
Yep I believe you can see that done in one of Seans demo vids
I am here: http://maps.google.com/maps?ll=-31.714124,115.803940
Old 02-24-2012, 09:17 AM
Bubblegum Bubblegum is offline
Default Re: eleven rack reamp question
Yes you can do that.
By setting the "output to amp" output (there are 2 to choose from) to "Rig Input", you won't even need to bypass any of the amps or effects settings on the 11 rack.
Then you just send your back into either the built in mic pre or an external pre into the lin ins or S/Pdif ins.
Very easy.
MojoBat Productions
Can't ReAmp in Eleven Rack (output inactive) jlg75 Eleven Rack 4 02-07-2014 10:10 AM
cannot reamp using eleven into fasttrack c600 into pro tools clydey Windows 8 08-02-2012 04:31 PM
How to reamp with eleven rack???? TeamContra Eleven Rack 3 09-07-2011 06:22 PM
Eleven Rack Hardware Reamp negative latency AKA Early??? finkbmx Eleven Rack 1 03-01-2011 05:34 AM
How do you Reamp using 11 Rack? tom hess macOS 3 02-07-2011 01:36 PM
