Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 08-15-2013, 04:28 AM
beezischillin beezischillin is offline
Default Windows 7/8 x64 Fast Track mk II USB driver issues
Hello all,
I have a laptop featuring running on an Intel Ivy Bridge i7, 16 gigs of DDR3-1600, an Intel series 500 SSD and some random 750gb 5200 rpm internal hdd drive.
I installed a win7 back in October on it and I had to reinstall recently, because my OS got old and filled up with unnecessary stuff so I decided to go with Win8. Downloaded the most recent drivers for every device, including my Fast Track. I've been having serious issues with it.
Sound randomly started distorting, cracking, until I restarted my PC, or worse, caused a bluescreen. From what I've managed to deduce is that USB3 + the Fast Track drivers are the cause of the issue. I've downgraded to W7 again. No distortions this time, only sound crackling, DPC latency problems, DPC-related bluescreens when plugged into usb3. It is weird, because they happen randomly while using the machine and it is pretty problematic. For example, if I start up an mp3 while, for example running Crysis, sound starts crackling so badly, that I need to shut winamp down. Since this is nowhere near low latency usage, it is a pretty big issue. The internal Realtek works pretty fine, if I switch to it, or the generic windows driver.
As far as I can tell it is not related to any of my Intel/Atheros drivers because I tried every possible combination, including those I've used in October. It is only happening when my interface is plugged in and when the driver is installed. When I use the Microsoft generic driver, it works perfectly well. But then again, if I do that, I am losing ASIO so it is a bit imperative to find a solution. Any ideas, please?
Thank you
Old 08-15-2013, 12:53 PM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Windows 7/8 x64 Fast Track mk II USB driver issues
It is generally recommended to disable WIFI when recording (although I dont). Have you gone through the Optimization Guides? I'm not sure if USB3 support has been improved, but I recall there being some problems with it:http://avid.force.com/pkb/articles/e...3D0&popup=true
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 08-18-2013, 06:32 PM
helloes. thanks for the reply. it is not wifi-related. I've tested it with every networking device disabled, etc. it is a driver issue, thus it prevents anything else than the 2010 driver to be used, essentially killing win 8 support. Ever since I reinstalled that, I can at least use my device without bluescreens, but it is weird and has latency issues
Old 10-10-2013, 01:57 PM
Souvlaki Souvlaki is offline
I too have had the problems described above with my M-Audio Fast Track Pro. It happens with general use and nothing of "heavy load" for example, opening then closing media programs and then trying to play a song. The sound will quit midway through or when playing another. Then when turning the fast track pro on and off, switching between sound outputs I get a bsod. I noticed with DPC latency test that the levels are fine 70-450 milliseconds but when the sound stops, its a constant 14,000 milliseconds of latency.
M-Audio Fast Track Windows 8 Installation/Driver Problems ewatson Pro Tools M-Powered (Mac) 1 11-01-2013 11:22 AM
Driver problems with Fast Track Pro USB musictomyears FireWire and USB Audio Interfaces (Mac) 1 10-15-2013 12:16 PM
Problemo of new Fast Track 6.1.12 driver tkrojam FireWire and USB Audio Interfaces (Win) 2 07-20-2013 10:17 PM
Windows 8 Driver for M-Audio Fast Track Pro kolibri Windows 6 03-28-2013 06:41 AM
