Waves plug-ins on Pro Tools First
Hi there! I have successfully installed Pro Tools First on my AMD system. Thank you very much Avid for this. That means if I purchase the full version of PT 12 it would run on my system right?
PTF can't seem to detect the rest of my Waves plug-ins. I have the latest version of them w/c I know includes aax compatibility. All I can see is the wave re-wire plug-in. I hope someone can help me out here. It would really be great if I can use an instrument from Waves. Thank you very much. Last edited by dhyowi; 08-10-2015 at 07:57 PM. |
Re: Waves plug-ins on Pro Tools First
what did Waves say? they have very good support and are very fast.
Just sent them the query. Thanks for the advice. Will wait for their reply.
AMD A6-3670K, Windows 8.1 (64), Komplete Audio 6, Cubase Artist 8, Pro Tools First |
Pro Tools First will not load 3rd party plugins that aren't distributed via the Avid store.
Let me ask you this, does it mean that Pro Tools 12 will run on my system? I don't seem to be having any other issues, at least up to this point.
AMD A6-3670K, Windows 8.1 (64), Komplete Audio 6, Cubase Artist 8, Pro Tools First Last edited by dhyowi; 08-10-2015 at 01:11 PM. |
I must say, I'm really amazed at how fast Waves support replies to e-mails. The last one I received from them took 3 minutes from the time my e-mail was sent.
Run well, don't know.
Thank you.
SiSoftware Sandra ID Host Name : Tobias-PC Workgroup : WORKGROUP Computer Model : OEM Serial Number : To Be Fille*********** Chassis : Desktop Mainboard : ASRock A75M-HVS BIOS : AMI (OEM) P1.80 05/26/2012 Total Memory : 15.75GB DIMM DDR3 Processors Processor : AMD A6-3670 APU with Radeon(tm) HD Graphics (4C 2.7GHz, 533MHz IMC, 1MB L2) Socket/Slot : FM1g1 (PGA) Chipset Memory Controller : ASRock F12 (Llano) APU Root Port 100MHz Memory Controller : AMD F12/14 (Brazos/Llano) APU Root Complex 100MHz, 2x 8GB DIMM DDR3 1GHz 128-bit Memory Module(s) Memory Module : Kingston 99U5471-054A00LF 8GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Kingston 99U5471-054A00LF 8GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : Samsung S19C150 (1600x1200, 18.5") Video Adapter : 3x AMD Radeon HD 6570 (6CU 400SP SM5.0 650MHz, 2.3GB DDR3 1.33GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 6570 (480SP 6C 650MHz, 2GB DDR3 1.33GHz 128-bit) OpenCL GP Processor : AMD Radeon HD 6530D (320SP 4C 650MHz, 1.8GB 128-bit) Compute Shader Processor : 3x AMD Radeon HD 6570 (400SP 6C 650MHz, 2.3GB DDR3 1.33GHz 128-bit) OpenGL Processor : AMD Radeon HD 6570 (400SP 6C 650MHz, 2GB DDR3 1.33GHz 128-bit) Storage Devices TOSHIBA DT01ACA050 (500.1GB, SATA600, 3.5", 7200rpm, 23MB Cache) : 466GB (C:) (D:) WDC WD10JMVW-11AJGS1 (1TB, USB2/SATA300, 5400rpm, SED, 8MB Cache) : 931GB (G:) TSSTcorp CDDVDW SH-224DB (SATA150, DVD+-RW, CD-RW, 768kB Cache) : N/A (F:) WD Virtual CD 0810 (31.5MB, USB2) : 30MB (E:) Logical Storage Devices System Reserved (D:) : 100MB (NTFS, 4kB) @ TOSHIBA DT01ACA050 (500.1GB, SATA600, 3.5", 7200rpm, 23MB Cache) My Passport (G:) : 931GB (NTFS, 4kB) @ WDC WD10JMVW-11AJGS1 (1TB, USB2/SATA300, 5400rpm, SED, 8MB Cache) Hard Disk (C:) : 466GB (NTFS, 4kB) @ TOSHIBA DT01ACA050 (500.1GB, SATA600, 3.5", 7200rpm, 23MB Cache) Optical Drive (F:) : N/A @ TSSTcorp CDDVDW SH-224DB (SATA150, DVD+-RW, CD-RW, 768kB Cache) WD Unlocker (E:) : 13MB (UDF, 2kB, Read-Only) @ WD Virtual CD 0810 (31.5MB, USB2) Peripherals LPC Hub Controller 1 : ASRock Hudson LPC Bridge Audio Device : HIS (Hightech Information Systems) Turks HDMI Audio [Radeon HD 6000 Series] Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Parallel Port(s) : 1 Disk Controller : ASRock Hudson SATA Controller [IDE mode] Disk Controller : ASRock Hudson IDE Controller USB Controller 1 : ASRock Hudson USB XHCI Controller USB Controller 2 : ASRock Hudson USB XHCI Controller USB Controller 3 : ASRock Hudson USB OHCI Controller USB Controller 4 : ASRock Hudson USB EHCI Controller USB Controller 5 : ASRock Hudson USB OHCI Controller USB Controller 6 : ASRock Hudson USB EHCI Controller USB Controller 7 : ASRock Hudson USB OHCI Controller SMBus/i2c Controller 1 : ATI SB800 SMBus Printers and Faxes Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : HP Deskjet 1510 series (600x300, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Scanners and Cameras Scanner : Hewlett-Packard HP Deskjet 1510 series (Scanner, USB) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 8.1 Home 6.03.9600 Platform Compliance : x64 Ain't running as smoothly as it was yesterday.
AMD A6-3670K, Windows 8.1 (64), Komplete Audio 6, Cubase Artist 8, Pro Tools First Last edited by dhyowi; 08-11-2015 at 03:27 AM. |
Waves Plug-Ins Not Showing up in Pro Tools 11 | protoolsgimp | Pro Tools 11 | 8 | 07-08-2013 08:00 AM |
Pro Tools 9.2 Waves Plug Ins | batistamusic | Pro Tools 9 | 4 | 09-01-2011 05:51 PM |
Pro Tools LE 7.4 & Waves Plug Ins | dsaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-28-2009 11:57 PM |
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP | toustab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 03-14-2009 01:13 PM |
Importing Waves plug-ins in Pro Tools | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-19-2005 01:24 PM |
