What happened to the answerbase!?
I used to be able to get into the answerbase and type an error message exactly as it appears and usually I would find a help doc. It's not there anymore, what's going on?
Re: What happened to the answerbase!?
Here is the old answerbase http://archive.digidesign.com/support/
I wear the pants. (My wife picks them out) |
The FAQs in Support are the same as the Answerbase. For search tips, see the DAE Errors & Search Tips under Quick Links in the Support section:
http://www.digidesign.com/index.cfm?...3&itemid=25511 Every item in the old Answerbase database was imported into the current website support section. The difference is the way the search engines work. On the old Answerbase (on the archives), you could search for -6042 and get the results for error 6042. On the current website, you would need to search for 6042 without the minus sign, since the minus sign means "omit", same as if you were doing a Google search.
Administrator Avid Pro Audio Community |
Answerbase??? | LeGato | Pro Tools TDM Systems (Mac) | 2 | 07-03-2006 11:44 PM |
updates to Answerbase please | Craig F | General Discussion | 1 | 04-28-2005 07:38 PM |
This should go to the ANSWERBASE | syra | Pro Tools TDM Systems (Win) | 3 | 03-21-2005 09:51 AM |
AmpliTube DOA: PT LE 6.4 (XP), AnswerBase no help | Wes Carroll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-01-2004 09:08 PM |
Answerbase | maxserg | Pro Tools TDM Systems (Mac) | 1 | 04-26-2001 09:24 PM |
