Old 05-30-2005, 03:59 PM
kurt's Avatar
kurt kurt is offline
Default DMP7 Mixer, as control surface?
Hi. Can one adopt Yamaha, 8ch. DMP7 Mixer, as control surface?
Is there any chance?
Thanx.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 05-30-2005, 07:30 PM
3001 Studios 3001 Studios is offline
Default Re: DMP7 Mixer, as control surface?
It's possible to control your virtual mixer from the DMP7, but probably not have it respond to the computer unless you write a program to make it emulate a HUI or Mackie control, etc.
I did some extensive work with DMP7's years ago. The main functions (faders, pan, etc.) send standard midi control messages which could be mapped to similar functions in your DAW application.
Since I was using multiple DMP7's as a digital mixer, I wrote an application in Max that allowed the computer to display all the DMP settings, and interactively access the hidden controls (EQ's, sends, etc.).
Old 05-30-2005, 08:23 PM
Avid's Avatar
Avid Avid is offline
Administrator
I'm not familiar with the DMP7, but you may be able to program it to emulate a CS-10:
http://www.digidesign.com/download/controllers/
See the MIDI Control Surfaces Guide, Appendix A, Using Other MIDI Controllers. Depending on your version of Pro Tools, you may need to also download the CS-10 profile from that page if you don't already have it in your controllers folder.
Administrator
is it possible to have 002 mixer as control surface only? internationalnova 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-11-2012 08:50 AM
analog mixer + control surface = digital mixer? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-11-2006 05:12 AM
Digital Mixer as Control Surface Tukkis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-17-2003 06:46 AM
Best Mixer/Control Surface for 001 ian benn General Discussion 6 01-31-2003 04:38 AM
Control surface/mixer? TRK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-03-2001 01:51 AM
