Would a better graphics card help my Pro Tools performance issues?
I'm on a bit of a tight budget, and have just upgraded my CPU to a Quad Core 2.4ghz Intel chip. I've got 2gig DDR2 ram, but still the system barely seems any faster than my old Dual Core 1.8ghz chip. When running a (relatively) large session, Pro Tools chugs big time, and I often have to switch the buffer to 512 or 1024 when mixing, but also the screen updates very slowly and jerkily.. which lead me to think, is my CPU being bogged down in displaying graphics too much to be able to run PT8 fast enough? I've set the windows 7 display settings to basic, and that improves things a bit.. which would seem to back up my theory. The gfx chip I currently have is a basic intel chipset on my cheapo motherboard. I think it only has 8mb..
So I've seen some GFX cards, such as this one which are dirt cheap.. so would this make a big difference to Pro Tools? My Sandra report is below: SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : GeorgePC User : George Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5KPL-AM IN/GB BIOS : AMI 0401 04/23/2009 Bus(es) : ISA X-Bus PCI IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 2GB DIMM DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 266MHz (1GHz) Total Memory : 2GB DIMM DDR2 Shared Memory : 8MB Memory Bus Speed : 2x 399MHz (798MHz) Memory Module(s) Memory Module : 256X64M-80F 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : Intel(R) G33/G31 Express Chipset Family (Microsoft Corporation - WDDM 1.0) (8 SP, Integrated Graphics) Storage Devices Hitachi HDS721616PLAT80 (160GB, ATA133, 3.5", 7200rpm, 7MB Cache) : 149GB WDC WD5000AAKS-00UU3A0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) LITE-ON LTR-48125S (ATA33, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Work (D:) : 466GB (NTFS) @ WDC WD5000AAKS-00UU3A0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (C:) : 149GB (NTFS) Optical Drive (E:) : N/A @ LITE-ON LTR-48125S (ATA33, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS 82801GB/GR (ICH7) LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : ASUS 82801G (ICH7) High Definition Audio Audio Codec : VIA 4397h Serial Port(s) : 1 Disk Controller : ASUS 82801G (ICH7) Ultra ATA Storage Controller Disk Controller : ASUS 82801GB/GR/GH (ICH7) Serial ATA Storage Controller USB Controller 1 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 2 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 3 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 4 : ASUS 82801G (ICH7) USB Universal Host Controller USB Controller 5 : ASUS 82801G (ICH7) USB 2.0 Enhanced Host Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter 1 : Belkin High-Speed Mode Wireless G USB Network Adapter (802.11g (ERP), TKIP, 18Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x86 Windows Experience Index Current System : 3.3 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Would a better graphics card help my Pro Tools performance issues?
Well integrated graphics are not supported, so yes, you need a dedicated video card.
Also it would help if you upgraded to 4GB of ram. and are you recording to a 2nd hard drive, NOT to the OS drive? Have you done the opts. ? Windows 7 Optimizations Avid Windows 7 Optimizations Video Playlist - YouTube
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Thanks for such a quick reply. I am recording to the 2nd HD, called "Work", yes. I haven't done the win7 optimisations, so I will do, thanks. I'll get the video card then! thanks |
Yes, Benoni is on the money. You will need to go into BIOS and disable the integrated graphics(tell the computer to look at the PCIe slot for graphics). That graphics card you linked to should work fine. When you double up the RAM, you need to get the exact same RAM chip that you have(mis-matched RAM can really slow things down). A few tweaks you need to do: disable the wifi when running Pro Tools. Go into Device Manager?Hardware and open up the USB devices. Double-click on any "USB Root Hub", select the Power management tab and UN-check the box. Then do all the tweaks from the link Benoni posted,
Thanks for expanding on that Albee, i did forget to mention to make sure you get matched ram.
I would personally, take out the 2GB you have, and then consult the QVL for your motherboard, and buy a 4GB set or 2 - 2GB sets that are identical. Just consult the QVL or go to Crucial.com and let them analyse your system so you know how much your Mobo can use, how much it can use in each slot, and what speed is supported. If i selected the correct motherboard, you have 2 Ram slots. each can hold up to 2GB per slot. So 4GB total. DDR2 PC2-8500 4GB kit (2X2GB) is recommended. http://www.crucial.com/store/listpar...model=P5KPL-AM I dont buy from Crucial (any more) i buy from Newegg.com as I prefer OCZ Ram, I just use Crucials analyzer. Consult your QVL for the Ram that has been approved. You can always hang on to the old ram as a backup, or sell them for $30 or so on eBay, or put them in another PC you may have laying around. I agree that the Video Card you linked should work. Be sure to upgrade to the latest driver on www.geforce.com Nvidia will scan your PC for you and list the correct driver. I wouldnt even bother with the drivers on the disc that come with the video card. Im suprised you even got this PC to run PT. I have a G31 chipset and a G33 chipset PCs that refused to run PT, so good goin. definitely start with the Video card, and if you feel you need more power, upgrade the ram.
Thanks for the help guys.
Got it going much better with all the suggestions. Just one thing though - the disabling the integrated graphics - you mean do this *after* installing the new PCI video card right? Just checking in case disabling it means something other than switching it off totally! I'm gonna get the new video card next week.. then another 2gig of the same DDR memory module. I can get it from the same place I got the first one so it should be identical. thanks for the help. much appreciated. |
Well some/most PC automatically turn off Integrated Graphics when a card is installed. Just go into BIOS and make sure
Ok, cheers guys. I'll see what happens and come back to you if I need more help.
thanks |
Exactly. But double check BIOS to make sure this its turned off if thats an option.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
PT HDX 11 slow performance due graphics card | Timo | Pro Tools HDX & HD Native Systems (Mac) | 13 | 02-08-2015 08:42 AM |
Graphics card for pro tools 10 | Shostakovich | Windows | 6 | 07-07-2012 06:51 AM |
HD Native Card Possibly Fried My Graphics Card | witrelo | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-14-2011 11:46 AM |
Do I need dedicated graphics card to run Pro Tools with hd picture? | RobertPaulson | Pro Tools 9 | 4 | 09-12-2011 09:05 AM |
Pro Tools 8 Performance Issues. | TLK Tom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-19-2008 06:36 AM |
