Old 03-24-2018, 12:51 PM
JR Fountain JR Fountain is offline
Default Feet and Frame Reset in Super sessions?
Hey you LA folks,
How do you deal with the fact that PT requires you to reset the footage counter at the beginning of each reel in a super session? It's annoying having to constantly reset it when doing fixes during a mix.
Thanks!
JR
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 03-24-2018, 03:31 PM
dr sound's Avatar
dr sound dr sound is offline
Default Re: Feet and Frame Reset in Super sessions?
Well it's 5400 Ft every hour so when you go from Hour 1 to Hour 2 it's 5400 more feet. I don't know how you can change that other than zero out the footage every hour. It's not that big of a deal as it's on a pul down menu "zero out footage".
If someone has a "trick" way of doing it I'm also interested.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 03-25-2018, 10:17 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I have a macro somewhere which does the following:
(prior setup involves creating a keyboard shortcut for "Current Feet+Frame Position..." by pressing cmd+opt+ctrl+p in system preferences)
• Prompt text box asking which reel to go to
• Enter your number
• Set main ruler to Timecode
• Press =
• Press right arrow (to go to hour)
• Input the number I chose previously and press enter
• Then press cmd+opt+ctrl+p
• type 0 and press enter
• Set main ruler back to F+F
I'll try to post the macro/video of it at work. It makes more sense to see it than read this.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-25-2018, 01:06 PM
BScout BScout is offline
• Enter your number
• Press =
I like this. With Eucon, you could set this up with a single press and no prompt for every reel (on the S6 or Dock/App).
One thing (if Avid ever fixes this) the "right arrow" should really be "left arrow". Right arrow should take you to the frames (utmost right of selection). Currently, both take you to the hour so it works either way.
Old 03-25-2018, 02:16 PM
dr sound's Avatar
Thanks Ryan! Do you use that Macro on the ADR Stage?
aka dr.sound
www.thedubstage.com
Old 03-25-2018, 02:26 PM
Ryan Young's Avatar
The ADR stage is chock full of amazing things that I wish I could take credit for. The F+F reset is one of them. I set up the film in a super session and jump from reel to reel within seconds if the cues are done in F+F.
I just made a new script since I couldn't find my old one. NOTE: I figured out how to avoid needing to set up the system preferences shortcut but you still need something to trigger this as an app, like FastScripts.
set xReel to display dialog "Which reel would you like to go to?" default answer "#" with icon note buttons {"Cancel", "Continue"} default button "Continue"
tell application "Pro Tools" to activate
delay 0.1
tell the application "System Events"
tell the process "Pro Tools"
perform action "AXPress" of menu item "Timecode" of menu "Main Counter" of menu item "Main Counter" of menu "View" of menu bar item "View" of menu bar 1
delay 0.1
keystroke "*"
delay 0.15
key code 124
delay 0.1
keystroke (text returned of xReel)
delay 0.1
keystroke return
delay 0.1
perform action "AXPress" of menu item "Feet+Frames" of menu "Main Counter" of menu item "Main Counter" of menu "View" of menu bar item "View" of menu bar 1
delay 0.1
perform action "AXPress" of menu item "Current Feet+Frames Position..." of menu "Setup" of menu bar 1
delay 0.1
keystroke "0"
delay 0.1
keystroke return
delay 0.1
end tell
end tell
-Ryan Young
Additional Systems
Old 03-25-2018, 03:57 PM
dr sound's Avatar
Thanks Ryan!
I'll try out "FastScripts" and see how it works!
Also thanks to JR Fountain for starting this post!
aka dr.sound
www.thedubstage.com
Old 03-25-2018, 06:26 PM
haha, no probs Marti!
Ya, it's not a huge deal but thought I'd ask since we don't use feet+frames on a regular basis. We're just used to typing in timecode values anywhere in the session and getting to that spot instantly without any menu clicking.
JR
J.R. Fountain
Old 03-26-2018, 05:59 AM
simonchase simonchase is offline
Requested 2011
https://protools.ideascale.com/a/dtd...a-tab-comments
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 03-26-2018, 09:16 AM
Norad155 Norad155 is offline
Serious question...
Why does anyone still use Feet+Frames?
I haven't seen it in a long time here in NY...
Is it the norm out in LA still?
(And I know it's not up to the sound department anyway...obviously if the pix department is working that way...)
It made sense when physical film still existed... but now seems a relic of a bygone era...
edit: also to keep it on topic...
I have 2 macros set up... 1 that swaps main counter from TC to F+F (or vise versa) and the other sets current TC to 0 Feet... so I switch to TC, navigate to the proper hour... zero out F+F and switch back... 3 buttons, but works quick
IMDB
HTML code is On
Feet and Frame with 29.97 Timecode Ruler audiosf Post - Surround - Video 6 04-26-2011 08:45 PM
Free Frame Rate and Frame Calc widgets dr sound Post - Surround - Video 1 08-21-2008 11:39 AM
how do U merge sessions w/different frame rates??? ejsongs Pro Tools TDM Systems (Mac) 6 09-16-2005 08:50 PM
Super tap only working on certain sessions...? Anthonygallo Pro Tools TDM Systems (Mac) 0 08-30-2004 04:33 PM
HD SNAFU alert. Feet/Frame ruler? rbeggs Pro Tools TDM Systems (Mac) 3 06-28-2002 03:20 PM
