PT Crash Urgent
Hi Guys,
It seems that every time I close PT it crashes. It reads: "Segmentation Fault" in the thread. "MainThread", at address 0xbfff02c0 I've dumped all my DigiDatabses but it keeps coming back. The closet thing I found in the "search" was being related to ReWire plug-ins but I don't have any open in these sessions. Any help? All the best, Mitch I'm working with PT 7.3cs3 on a Mac G5 2.0 5 GB Ram
Best Mitch MacPro 2.44 8 Core Mac OSX 10.10.5 PT 12.7 HD Native SyncHD I/O HD I/O MIDI I/O C24 Aja LiHi Surround Setup |
Re: PT Crash Urgent
If you don't need the rewire plugin then move it to the Unused folder.
It gave us a whole heap of problems just by being the in Plug-Ins folder |
Re: PT Crash Urgent
Thanks
Not good because I'm sometimes working with sessions with Source Connect which uses ReWire. So your saying even if that actual plug-in isn't even being used in the session it still causes problems??? All the best Mitch
Re: PT Crash Urgent
Yeah, don't use rewire on a regular basis (occasional SourceConnect use on one system) Even having the plugin in the folder causes problems like you are describing occasionally.
Check that the version you have is up to date though. I just removed the plugin on our clone disc which has helped but I'll have to reinstall it soon as we are switching to SoundMiner. |
Re: PT Crash Urgent
I just went through this, although I got no error messages. Do a disk utility on your start up drive. Mine was fried in spots and couldn't be repaired. I had to get a new startup drive and reinstall everything. Not fun. Type in "computer crashes" in Search The DUC" and read through my thread from a few days ago. Folks had some good suggestions...might help you.
Crash crash crash crash crashhhhh crahshrbnjfgeviufdbldfgvjndgokhng | FuneralMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 11-16-2009 12:02 AM |
URGENT URGENT Hard Drive problem please help | arcarsenal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-28-2005 12:02 PM |
New Crash, "Save As Bug" Digi !!!**URGENT!!!** *DELETED* | Keith Owens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 01-01-2005 04:21 PM |
Installed 32track le version, won't run with Reaktor crash crash crash | Christian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-02-2002 11:05 AM |
Urgent gelp!!! 5.1.1 does not open anymore x Hd crash | Alécio Costa | Pro Tools TDM Systems (Mac) | 32 | 08-07-2002 09:37 AM |
