automating plugins/faders in Vienna Ensmble via PT
Hey guys. does anyone know if you could automate plugins and/or faders in VE pro running through PT10/11?
Thanks!
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Re: automating plugins/faders in Vienna Ensmble via PT
Yes, you can automate plugins. I can't speak on VE Pro as I haven't used it...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
There's a good video tutorial over on Groove3 showing host automation in VEP. http://www.groove3.com/str/Vienna-En...Explained.html
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Thanks Chuck, I'll check it out.
Chris- my question was specific to VE pro. No need to chime in if you're not hip on the topic.
Yes you can, but you must prepare each VEP Pro instance you use (because each instance has a different mixer).
In each instance of VEP, you must allocate each volume, pan, volume send, etc to an automation parameter (called "param1", "param2", etc up to "param512"). -> Menu View / Automation Mapping (F5) You have an auto-map feature which will make this for you (it is faster, and will allocate parameters the same way for all instance but may not suite your needs). (note : You can also use MIDI CC instead of automation parameters). Then in Pro Tools, you simply needs to enable all the parameters you want to automate in the VEP instance's plug-in window (like you would do for any plug-in) but parameter's names are generic (will only show "param1" to "param512"). So it may be better to use the same numbering for each instance to make it easier to use (ex : param1 to 32 for volumes, param33 to 64 for pans or always use auto-map for each instance).
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
Thanks for the detailed reply!
Automating Plugins | chagmaier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-22-2012 10:39 AM |
Controlling Vienna Ensemble Pro faders from Pro Tools? | Erik Olsson | Pro Tools 9 | 1 | 10-14-2011 08:02 AM |
Automating several plugins | schlawingo | Tips & Tricks | 8 | 02-25-2010 01:06 PM |
Automating send faders on HUI controller ? | Ross H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-30-2005 09:33 AM |
automating plugins | viaspiaggia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-31-2004 10:10 PM |
