Re: PT 11 and Focusrite Headphone Mixes
Are your two units locked via ADAT? If so, you should be able to use the Pro14's as another out. The one thing I found though with my Octo, is that you can't use the ADAT locked devices as instersts, as the the outputs only mirror the mic pre ins (only the OctoPre Dynamic allows that type of routing) Try setting your ADAT out 1/2 to the corresponding DAW output of the Aux you set up in PT. Good luck
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Hi nwrstudio, Yes you can send another cue mix from the pro 40 to the pro 14 using spdif. On the pro 14 you can use either the mon outs or the line outs 3 and 4
Thank you!
The Freakin' Harborcreekin' www.norwegianwoodstudio.com Sweetwater Creation Station 400 i7, 3.4 ghz, W7 Home Premium, PT 11.3, Focusrite Saffire Pro 40 & Pro 14, Focusrite Octopre Mark II, A&H GL2400/24, Event 20/20 V2's, 2-24" Video monitors, a whole buncha hard drives, 3 lava lamps AND an official "unsuck" button!! |
Headphone mixes | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-09-2008 08:56 AM |
Headphone mixes | JBT24 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-23-2005 01:03 PM |
PT and headphone mixes. | hbj | Pro Tools TDM Systems (Mac) | 3 | 08-22-2003 02:51 AM |
Headphone Mixes With 001 | Tracy Lowery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-16-2002 04:42 PM |
C24 @ Headphone Mixes (again) | nutshell | ICON & C|24 | 2 | 06-23-2002 06:43 PM |
