Automation edit with the trim tool?
When I make a selection on a volume track and use the trim tool to raise or lower the volume automation in the selection, the selection boundaries change with the selection and make an instant volume change at those points. Is there a setting that will force those situations to be a slope instead of a vertical change?
Those sudden vertical changes are not always so great sounding.
q6600-ASUS P5K SE(P35),2GB Crucial BallistexDDR2 800,ASUS EN7200GS 256MB,80GbMaxtor-80GBWestern Digital,Samsung SATA DVD burner,Mbox2 PTLE 7.4cs7 |
Re: Automation edit with the trim tool?
I meant to post this in the windows forum. Sorry about that. A solution might be the same either way.
Thanks Spaids
Resolution when adjusting automation points with trim tool | mahler007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-09-2010 06:44 AM |
Automation edits with the trim tool? | spaids | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-27-2009 04:50 PM |
Problems with Grabber Tool & Trim Tool | S133 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-05-2008 10:19 PM |
Region Trim - Automation not following edit | simonchase | Pro Tools TDM Systems (Mac) | 1 | 06-07-2007 01:29 AM |
Using the trim tool to edit your automation - quick ??? | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-15-2001 12:26 AM |
