Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 01-09-2017, 05:46 AM
taylor4814 taylor4814 is offline
Default Precisely Match L-R Powered Monitors Level Setting?
With two powered monitors, L-R, with manual volume control knob on the back, is there some electronic, or other, way to precisely match their level setting to match, rather than just eyeballing the knob setting?
Old 01-09-2017, 06:13 AM
conleec conleec is offline
Default Re: Precisely Match L-R Powered Monitors Level Setting?
Get a sound pressure level meter. Lots of them available on Amazon for relatively cheap. Use a consistent reference, such as pink noise.
https://www.amazon.com/s/ref=nb_sb_n...ords=spl+meter
Chris Conlee
PTHD 2018.1, Behringer FCA610, Blackmagic Intensity Pro (driver v10.8.2)
Mac OS 10.13.2, 2009 Mac Pro, 32Gb RAM
Old 01-09-2017, 11:38 AM
Indeed^^^ Or simply make a mono AUX track, insert the signal generator plugin, set pink noise at a comfortable volume, sit dead center of the speakers and adjust until the sound seems to come from...dead center
Old 01-09-2017, 12:09 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by albee1952 View Post
...sit dead center of the speakers and adjust...
+1. If your gear & cabling are good, the L/R balance SHOULD be on-the-money. Use a mono source to verify. My rig was fine, but I double-checked (by ear) to be certain. It really was as simple as that !!!
Click for audio/video demo
Click for resume
Old 01-09-2017, 12:26 PM
Thanks, all...
Old 01-10-2017, 01:21 AM
luy luy is offline
What about running both all the way up? As long as you run through a monitoring unit you should be safe enough...
Old 01-10-2017, 02:15 AM
That's what I do most of the time, but sometimes need a lower setting..,
Old 01-10-2017, 06:13 AM
The amplifiers may not spec exactly the same. Also, it seems to me the sweet spot for most amplifiers is somewhere less than all the way up.
Chris Conlee
Shootout video comparing 12 vocal mics. How to level match in PT10? conrad787 macOS 9 09-28-2012 05:15 AM
Setting PT Timecode to match movie TC @creativelydes Post - Surround - Video 14 09-23-2011 05:42 AM
Aurora 16/192 + AES level match calibration Actionmusic Pro Tools TDM Systems (Mac) 4 02-15-2011 10:14 PM
Setting tempo to match a hit or set length tlester Pro Tools TDM Systems (Mac) 1 03-02-2006 03:56 PM
Setting MIDI tempo to match loop Matthiasalias MIDI 1 08-26-2004 10:49 PM
