Pro Tools Sends Issue
Hello,
friends pro tools 9 has sends A-E and F-J while mine only has Sends A and no other sends at all. When I select only one send the send which is a reverb is controlling the volume of my track but yet my friends pro tools 9 only controls the reverb not the volume of the track. Does anyone have a simple fix for these two issues I am having? Thanks
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
Re: Pro Tools Sends Issue
You have SendA expanded and your friend sees sendA-E and sendF-J assignments. Take a look at the menus, my friend, you can control how the mix and edit windows show up :)
View/Sends A-E/Assignments
It sounds like you are using an Aux with a reverb plugin and bussing a send to that:
Go to your reverb plugin and turn the "mix" to 100 percent wet. Now your send will only turn up the reverb.
bookerv12 |
okay but why is it that once I have my effect set to 100 percent wet the submix track doesn't fade out when the volume is all the way down?
pre fader is turned off on the send
source audio
Pro Tools 9, Eleven and Aux Sends | Becharax | Pro Tools 9 | 3 | 07-29-2011 10:17 AM |
Sends default to -inf preference...resetting all sends to 0 | Nathan W. | Post - Surround - Video | 3 | 07-15-2011 12:10 PM |
issue with AUX sends for phones | albee1952 | General Discussion | 3 | 04-13-2011 01:54 PM |
outputs vs sends for mixing down within pro tools | roark | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-30-2011 03:59 PM |
Pro Tools - inserts and aux sends | Raphael Rosenthal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 23 | 09-07-2001 08:26 AM |
