I/O Master?
I have one song where I cannot output the master. I usually output the master to stereo 1-2. I guess this has something to do with the I/O setup but I'm clueless.
Re: I/O Master?
First check the hardware setup, hit default if it does not make sense. Then go to i/o setup and do the same. These two are related and determine which physical i/o is being used.
Re: I/O Master?
I did both those things but still no luck.
Here's what it looks like: |
Re: I/O Master?
You have lots of paths in the pic past physical output capability, so either you have not done the default or you first need to delete everything and then hit default.
Re: I/O Master?
Just so I'm clear: delete all the "Paths" or the little boxes for mono, or both....or everything I can possibly delete?
Re: I/O Master?
Everything
Re: I/O Master?
That worked.
Thank you!! |
Re: I/O Master?
You're very welcome :)
Production Master Or Original Master | Zelos | General Discussion | 3 | 02-14-2011 07:52 PM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
TC Master X or Waves Master Bundle | TiPo | Pro Tools TDM Systems (Mac) | 4 | 02-15-2003 11:41 PM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
Master Fade & Master Plug Ins | Kenny Gioia | Tips & Tricks | 10 | 04-17-2001 02:39 PM |
