Old 01-25-2012, 04:24 PM
lukeyy lukeyy is offline
Default Protools is low on memory...
I´m getting this message all the time when I´m using a lot (4-5) kontakt engines - I have 14GB RAM and my activity monitor shows half of my memory free (green) - anybody with the same problem?
Old 01-25-2012, 04:45 PM
Craig F Craig F is offline
Default Re: Protools is low on memory...
but your only using a 32 bit app in Pro Tools
you need to look at an external VI host for your VIs
VEP seems to be popular
some like Reaper for hosting
Thank you,
Craig
Old 01-25-2012, 04:59 PM
@ndy's Avatar
@ndy @ndy is offline
Are you using the memory server? It's 64 Bit and works OK.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 01-26-2012, 05:24 AM
could you explain how I can do that? I´m on PT9.0.3 on a macpro intel with kontakt 4
Old 01-26-2012, 10:46 AM
@ndy's Avatar
In Kontakt, open the preferences and enable the memory server. You will have restart Kontakt for it to take effect. After you restart you will see a new icon on your menu bar showing the total size of samples loaded into RAM. When you quit Pro Tools the memory server keeps running, so you have to close it to clear out your RAM.
Old 02-21-2012, 05:49 AM
thx I´ll try
Protools low on memory? oneofmany 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-23-2011 11:59 AM
Protools Le 8.0.1 Draining Memory Win Xp JamesPondAqu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-17-2009 08:49 AM
how much memory i need to run protools streets 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 06-12-2004 11:13 PM
Allocating Memory to ProTools and DAE CircleMusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-22-2003 07:16 AM
ProTools CRITICALLY LOW on MEMORY??? BrandonABrown 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-01-2003 11:25 AM
