Output Issue
I recently hooked up a Mackie Onyx Artist 1.2 interface. It works well.
However, I thought I would be able to hear audio from other applications while PT is running. I set the Playback Engine to the Mackie ASIO driver, which is fine for PT. But, I still cannot hear other sounds from the laptop, not even the default chime from the speakers level adjuster. I must be missing something. I know I had to restart PT when I switched to the Mackie ASIO driver, and the session saved and restarted. I thought having an interface would allow me to have PT open and still hear audio from other applications. Please advise.
OMEN by HP Laptop 15-dc1xxx Intel core: i7-9750H-CPU 2.60GHz 6 Cores, 12 Logical Processors NVIDIA GeForce GTX 1650 Version 451.67 RAM: 32Gb (31.8 usable) Windows 10 Home x64 Running PT 2020.9.1 |
Re: Output Issue
If your Windows sound settings aren’t set to output via the Mackie interface, then you won’t hear them.
You may have difficulty getting that working properly with PT running. Multi client interfaces don’t seem to work well on Windows like they do on a Mac. Sent from my iPhone using Tapatalk |
Re: Output Issue
Which higher end interface could allow this option? What is DUC?
Re: Output Issue
Re: Output Issue
Digidesign User Conference, currently called Avid Pro Audio Community (this forum) but it has inherited the URL of duc.avid.com
Re: Output Issue
Best to assign your onboard soundcard to play Windows sounds, so your main Pro Tools interface can be that and ONLY that.
Side note. We couldn’t get my UA Apollo 8 TB to play nice with Source Connect, so I use a Focusrite Scarlett 2i2 for Source Connect and Windows audio. Sounds much better than the onboard sound card. |
Re: Output Issue
Does the UAD console allow you to do similar?
Re: Output Issue
“Does the UAD console allow you to do similar?“
It might, but I haven’t had the time or inclination to mess with it. I use one of the matrix outputs on my Soundcraft console to feed the Focusrite for SC. So if I want to record on my end while I’m sending with Source Connect, that operation is totally independent. Anything I assign to 7-8 on the console feeds Source Connect. So I can send 1 into Protools to record locally, and 7-8 to feed SC simultaneously. |
Re: Output Issue
Ah. since you have a physical mixer then there is no need to use UAD's Console.
Output Issue | PJ Brady | Pro Tools 12 | 2 | 10-26-2016 07:19 PM |
I/0 input output issue can someone help? | trevmunroe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-22-2014 10:50 AM |
Digi 192 I/O Output Issue | PatM01231 | Pro Tools TDM Systems (Mac) | 1 | 06-18-2013 11:08 PM |
96 IO output issue | robo6675 | Pro Tools TDM Systems (Mac) | 0 | 02-17-2010 07:20 PM |
Possible issue w/PRE's OSC output... | Armando | Pro Tools TDM Systems (Mac) | 1 | 02-18-2008 07:09 PM |
