Max track Count
I ran into a new wall on my MixPlus system that I haven't seen before. There appears to be a rather low limit(64 voice engine) as to how many tracks can have voices assigned(from 1st bank of 32). I believe at right around 44 tracks I got a message that no more voices could be assigned. So the practical limit to virtual tracks is 88, not 128.
Peter Cole |
Re: Max track Count
So what happened to 128!!!!!
Maybe NOBODY is using lot's of tracks... What's up DIGI?/??!!!! |
Re: Max track Count
Digi??????
Anybody else with these problem? |
Re: Max track Count
Have you tried changing the playback engine ?
"What's the best mic under $100." |
Re: Max track Count
Peter (hi!),
I often am running into this problem as well, but never found it to be 88 (unless I'm wrong, which is possible . It seems that it's very picky which voices you try to assign double. -cd |
Re: Max track Count
How does this add up to 128?
Out of all the things I lost, I miss my mind the most. |
Re: Max track Count
It seems that some confusion still remains here between voices and tracks. The track in your PT session is represented by a "channel strip" in your mixer or playlist in your edit window. The voice to which a track is assigned, is represented in the Mix and Edit windows as a button and pull down menu that allow you to assign your track to an available voice. Tracks that are not assigned to a voice can live in the session but remain "virtual". Hope this sheds some light, if not these concepts are covered in your Pro Tools Basics manual.
T.J. Thomas digidesign [This message has been edited by ProdInfo (edited 10-25-99).] |
Re: Max track Count
One thing that would help with this limtation is an update to Track Transfer. If the audio and/or automation could be transfered into the destination sesion without creating new tracks.
Peter Cole |
Re: Max track Count
Peter Cole |
Re: Max track Count
Peter Cole |
Track Count on HD 1 | mohoman | Pro Tools TDM Systems (Mac) | 3 | 01-05-2009 07:25 PM |
PT 8 Track count | chrisbarnett | Pro Tools TDM Systems (Mac) | 2 | 12-18-2008 01:56 AM |
PDC and track count | overflow | Pro Tools M-Powered (Win) | 2 | 07-28-2006 11:19 PM |
Track count? | JFreak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-26-2003 06:52 AM |
Track count: G4 PCI vs. G4 AGP | uno1234 | Pro Tools TDM Systems (Mac) | 3 | 02-08-2001 01:37 PM |
