Ungroup shortcut 'Ctrl+Alt+U' not working
I'm on a Win 8.1 PC running PT HD 12.4
Group shortcut 'Ctrrl+Alt+G' works fine Ungroup shortcut does not work |
Re: Ungroup shortcut 'Ctrl+Alt+U' not working
Easy one this: I note your location as 'London' so will guess you're using a UK keyboard & UK language setting in Windows. Unfortunately Pro Tools is quite fussy about the language setting and using non US language will break a number of shortcuts.
To solve: Add US input method (Control panel->Language->language options) US Touch keyboard layout. Starting Windows 8 (I think) you can set an input method (keyboard layout) per application, so you can have everything else work correctly, like @ & £ where you expect and still have Pro Tools behave. Control panel->language->advance settings->Let me set a different input method for each app window. Go to the taskbar and select US input method with Pro Tools as the focused app and you should be good to go. |
Brilliant, thanks a lot ex-user your solution works great, and thanks for the detailed guide on how to fix it with Win 8.1
The other common shortcut that fails to work, in fact it's how I test I've got the language set correctly are part of the selection navigation keys "LP;'" The ' key won't move selection right but instead cycles through the edit modes! |
S3 Fine Ctrl not working? | soundeditor76 | Avid S1, S3, Dock and Control App | 4 | 03-05-2020 03:09 PM |
Ctrl+Cmd+Space not working right in 10.3.... | David Hardie | Pro Tools 10 | 4 | 10-26-2012 03:33 PM |
Ungroup Clips Shortcut Not Working? | ChazC | Windows | 6 | 01-29-2012 03:32 PM |
Some ctrl functions not working | nciviero | Windows | 2 | 09-13-2011 09:39 PM |
ctrl+tab or ctrl+alt+tab not working | Sebastien Richard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-09-2006 10:10 AM |
