Travelling light – moving from laptop to iPad
“This story will make you rethink your portable rig and what’s possible with iPad recording”
https://www.audiotechnology.com/tutorials/going-further "Things are stepping up in the world of iOS audio. Greg Simmons updates ‘On The Go’, his story from 2018 about moving from laptop to iPad, with new solutions and new recommendations."
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife! |
Re: Travelling light – moving from laptop to iPad
I used the inverted commas as I was quoting Greg’s copy from the above URL.
The (16/24 bit 192 kHz recording) Nagra 7 is advertised from USD 3,300.00 to USD 4,500.00 https://www.trewaudio.com/product/nagra-seven/ Or you could snap one up for only $10,895 in Australia: https://audioconnection.com.au/products/1403 https://youtu.be/a5Pe5NcpRYA https://www.nagraaudio.com/product/nagra-seven-music/ Technical specification RECORDING Internal storage: Micro SD Flash memory card Removable media: SD Flash memorycard Disk format: FAT 16 / 32 Recording Method: Linear digital PCM, optional:MPEG 1 layer II File type: 16 / 24 bit Broadcast Wave File BWF (WAV) A/D & D/A: 24 Bit Sigma Delta Bit rates: 32 kbits/s up to 384 kbits/sec Tracks: 2 individual Sampling Rate: 44.1, 48, 88.2, 96, 176.4 and 192kHz Recording capacity: 1hr at 24 bit 48 kHz per GB of memory Pre-recording buffer: Programmable Display: Color LCD touchscreen Level meters: On colour display INPUTS Digital input: XLR 3-pole / AES 42 Analogue inputs: 2 x XLR Microphone (Dynamic, +48V Phantom) / line Mic. input sensitivity: 2.8, 10 and 40 mV/Pa selectable Mic. input noise: Uin < 1µV (2.8 and 10 mV) @ 220Ω Uin < 1.6µV (40 mV) Limiters: On microphone inputs Line input sensitivity: Adjustable from -6 dBm up to +24 dBm for 0 dBFS recording THD at 1 kHz: 2.8mV Mic <0.2%, 10mV Mic <0.1%, line <0.1% (measured on AES out) Frequency response: Mic, 10Hz – 75 kHz (+0 – 3dB), Line 10 Hz – 90 kHz (+0 -1dB) (measured on AES out) Signal-to-noise ratio: >110 dB ASA “A” Input level adj. range: 42 dB Mic and from -6 to +24 dB Line Input filters: LFA Internal microphone: On the front panel Crosstalk: Mic >70dB : Line > 110dB OUTPUTS Analogue line output: XLR 4.4V max (+15 dBm) Crosstalk: >110 dB Signal-to-noise ratio: >100 dB Digital output: XLR AES-3 (24 bit or 16 bit) THD+N: <0.004% Frequency response: 10 Hz – 75 kHz (+0-3dB) Headphones: Stereo 6.3mm (Ľ”) Jack 50 Ω Internal speaker: 0.3W OTHER USB: Micro AB connector M/S Decoder: Switchable Ethernet: RJ 45 GENERAL Dimensions: 165 x 175 x 65mm (W x H x D) (Incl. battery box) Weight: 800g (1.75 lbs) (Incl. battery pack) Power supply: External 15V Power Consumption: Approximately 5W Charge time: Approximately 3 hours Battery life: >5 hours Relative humidity: From 10% to 99% (non condensing) https://www.nagraaudio.com/wp-conten...n_EN_V2101.pdf PS - very happy with my Lenovo laptop – but window-shopping’s still legal, as long as my darling better-half's not watching!
Did the surprisingly limited/stereo Nagra 7 help Nagra's decline? Is any major pro-audio retailer even selling Nagra stuff anymore in the USA?
Couldn’t find it here:
http://eatswitzcheese.ca/ Probably prohibited by the Disk format: FAT 16 / 32
Best Remote Way to Run PT from Laptop or iPad | boogiemotel | macOS | 5 | 01-14-2013 07:51 AM |
Moving from iMac to Laptop | maccattack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-09-2011 08:20 PM |
Help! Moving Session from laptop to Desktop | jacknprewitt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-24-2009 07:36 PM |
Moving to Vista Laptop and discovered a problem | gsdesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 02-18-2009 09:22 AM |
Travelling with ProTools | jimmyriserock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-25-2006 05:15 AM |
