Click
Can I use some metronome inside the PT. I don't want to use an external devices. Maybe you have some idea for this.I need some kind of plug-in where i can choose MIDI IN and the audio signal will appear on aux or audio track.
I have PT TDM 6.7 Thank You Kamil Biedrzycki |
Re: Click
Is there a click plug-in in your version of PT? If there is not, use any virtual instrument and send "click signal" to it (somewhere in click options). If this instrument is VST/RTAS, beware of latency - I use Virus TDM with "Block" preset - works great. The best solution IMO is to copy and paste your favourite click sound to audio track - works if there is no tempo changes ;-)
Powodzenia, Przemek.
http://imaginatlh.com/91709 |
Re: Click
Yogev Samina |
Re: Click
I decided to use a sample with click and paste it into Audio track. It is the best possibility i think because it's very simple and easy but sometimes...
Thank You for answers Kamil Biedrzycki |
Re: Click
PT7 makes life better...
For those of us who like the idea of a "printed click" (such as what you said you are using now Kamil), keep in mind that you can make that Audio Track tick based! This way, if you adjust tempo, those printed, on-the-beat clicks stay with the beat. While the DigiRack Click plugin is cool, and will stay close to sample accurate for the most part, custom sounds for the actual "click" are sometimes desired. For instance, until I finish learning to code, the only way I can use my "Click-Cluck" idea is via audio track print. hehehehe!!!
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
Avid can you please sort out the click track & Click 2 plugin | protoolsuserman | Pro Tools 11 | 14 | 11-14-2013 08:11 AM |
Getting the click track to click at 16th notes... | broken81 | Tips & Tricks | 1 | 06-27-2008 07:06 PM |
Click Track - How to "UN" accent the click plugin | pepperbox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-02-2006 06:37 AM |
Mbox needs TWO click plugins for the click to work | drguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-17-2004 12:01 PM |
Power Harness, click click click | director | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-14-2004 09:50 PM |
