Drum Mapping in BFD Lite
I have a Roland TD3 electric drum set, ProTools LE 8, and BFD Lite. When I'm using the bfd lite and play the map for the drums is almost completely wrong - only the snare, hi hat, kick, and one crash cymbal are the right things. I've tried moving cable connections but the rest of the set doesn't register anything close to what they should be and I can't figure out how to change what sounds are triggered in the BFD. Any suggestions or how to's?
Re: Drum Mapping in BFD Lite
I have the same equipment and the same problem. I tried creating a drum map using the note numbers in the TD3 manual, but it still isn't right. Does anyone know where you can download an accurate drum map for the Roland TD3?
Use the Learn function in BFD or just record each note into Pro Tools... but first make sure that you have the -2 octave naming enabled in BFD
Rail
jjnb51, I've tracked down the drum map for the TD3, Send me your email address and I'll send you it.
Xpand 2 drum mapping question | stechdj457 | Virtual Instruments | 5 | 12-03-2009 04:57 AM |
Using Pro Tools Midi Editor for BFD2 drum mapping | Qrackaduck | Virtual Instruments | 4 | 10-15-2009 08:53 AM |
MIDI - Drum mapping | giove | Tips & Tricks | 15 | 09-26-2009 02:25 PM |
BFD Lite Drum Module | affreds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-28-2007 06:16 AM |
Drum editor / Mapping | Marlowe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-10-2000 12:19 AM |
