Old 08-03-2020, 08:16 AM
Rockman413 Rockman413 is offline
Default How to Enable PT in MMC Slave?
Hi there,
I know in Periphals we can check the box to enable machine control (slave) and set the ID to 127 , but is this all? is there a switch to toggle PT into MMC slave mode?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 08-03-2020, 03:02 PM
henningaround henningaround is offline
Default Re: How to Enable PT in MMC Slave?
AFAIK you also need MTC but when both is present and the slave box is ticked in the preferences Pro Tools should chase any incoming signal on that MIDI port by itself.
Set the 003 as slave KoMa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-26-2014 11:43 PM
slave another pc? mattytoldhatty Windows 3 12-16-2011 04:20 PM
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
Slave Mix to HD octagondd Pro Tools TDM Systems (Mac) 2 06-06-2003 02:03 PM
PT MMC Slave ? Toko Tips & Tricks 0 03-31-2000 02:40 PM
