Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-04-2014, 01:04 PM
Don Bravo Don Bravo is offline
Default Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem)
Hi
I am recording some music with
Eleven Rack
Macbook 4.1 Intel Core 2 Duo, 2.4 GHz
Mac OS X Version 10.6.8 Snow Leopard
Pro Tools 9.0.6
Alessis 10 DM module and pads
Addictive Drumms via midi
I'm having some latency issues, i connect the alessis dm 10 to the eleven rack via midi, the eleven rack to the laptop, i open pt 9, create a stereo instrument track, open on insert the addictive drummer and even though i already click the low latency option, when the drummer is hitting the pad, there is a small delay(Latency not an fx) and it messes up the rhythm while recording, and even when is not recording too... Any idea on how i can eliminate the delay or latency problem?
Old 07-04-2014, 01:23 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Re: Problem: Recording Electric Drums via Midi with Addictive Drumms (Latency problem
Did you try reducing your buffer size?
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
Old 07-04-2014, 01:31 PM
Yes, i tried with lowest buffer size and tried some other levels too.
Old 07-04-2014, 02:19 PM
Glenjb Glenjb is offline
Default Re: Problem: Recording Electric Drums via Midi with Addictive Drums (Latency problem)
This may not be what you want to hear but I have a vdrum setup and what I do when I want to record midi from them is to monitor my vdrum sounds while I'm recording even though the sounds are not as inspiring or even close to what I will end up using for VI drum sounds. I have the old td10 expanded Roland so it's pretty old but I made a kit that sounds pretty natural for general purposes.
There is a well known session drummer on another forum who has done a lot for toontrack and I saw that he does this as well which made me feel better.
I also spent some time tweaking the velocity response on my pads while recording midi into Pro Tools to make sure they are doing what I want and that they will translate to the VI's also without much tweaking.
I record the audio from my vdrums as well so I can check any weird midi notes against it. I will get something that's off every once and a while that I know I played well and I can line up the notes to that audio if needed.
Many do it the way you are but this is just way less of a headache for me...
Old 07-04-2014, 04:27 PM
At least is something, if there is no other solution, i will use it, thank you.
Old 07-04-2014, 11:49 PM
1 thing I can't tell if you missed or not is; DON'T have midi going BACK to the Alesis brain as it COULD cause double-triggers(this happened when I first setup with a Roland V-kit). Personally, with my old(now gone...and MISSED) TD-10 Roland kit and EZdrummer, Superior Drummer and Addictive drums, the response was very good and I rarely heard any mention of latency, even from "real" drummers(I can pound out a beat, but have to edit the daylights out of the midi). FWIW, I always track at the 64 buffer and never use LLM The ultimate(for me anyway) was a hybrid with real hat and cymbals on the TD-10 kit and Addictive or SD2 for shell sounds(although my current Sleishman "BOP" kit is AMAZING!!!(special thanks to Michael and Lee for the loaner kit). The 18" bass drum totally trashes my 24" house kit
Addictive drums problem in Pro tools elduderino macOS 3 08-07-2013 12:15 PM
pro tools problem with addictive drums mike666 Windows 3 08-06-2012 08:31 PM
Having a really weird problem with Reason and Addictive Drums... listenhard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-01-2009 02:37 AM
MIDI Latency Problems Recording Addictive Drums sventvkg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-08-2007 02:37 AM
MIDI Latency Problems Recording Addictive Drums sventvkg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-08-2007 02:34 AM
