H/W buffer problems on 1 drive only- an ANSWER
So-
From the GREAT dell tech support. When, after adding another hard drive you can't get the IDE "current transfer" (in the device manager under IDE's) from PIO to DMA (it's greyed out as PIO mode only). Here's the trick........thanks to Lee at Dell......... You have to go to BIOS, and then make sure the following on your keyboard is lit.... the num lock, the caps lock, and the scroll lock. then press alt f and wait for beep press alt e and wait for beep press alt b and wait for beep. Computer restarts, and rechecks all device/drive connections. At that point it "sees" and engages the 2nd drive fully. Then go to Device Manager and witness the miracle- the PIO is finally switched to DMA (DMA mode is finally seen by the stupid computer). This solved my H/W Buffer problems and CPU problems on my Win XP PT 6.1.1 (occuring on slave drive only) I have no other answers but this. Good Luck and thanks to Digi for trying to help. Best K |
Re: H/W buffer problems on 1 drive only- an ANSWER
well wasn't that method obvious?
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
Hard Drive not set to Audio Record Volume Answer | Guitarman002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-09-2009 01:29 PM |
Havin Problems with Buffer or WD Audio Drive? Here's my fix! | Table Syrup Records | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-26-2007 08:03 PM |
Buffer Errors- The Answer | Dawg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-14-2007 08:25 AM |
Buffer Errors / Buffer Problems? | freezegelman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 11:50 AM |
Firewire drive and buffer size? | BForrester | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-22-2004 09:10 PM |
