Old 04-13-2013, 04:46 AM
Tigerspill Tigerspill is offline
Default S/PDIF (from Delta 1010) to AES on SC48
I have a PC with an M-Audio Delta 1010.
The PCI card has a S/PDIF digital output on two phono connectors (Input and Output).
How do I convert this output to the single AES XLR digital input on an SC48?
Does the single phone output on the PC card and single XLR input on the SC48 carries a stereo signal?
I only need stereo from the PC so dont want the hassle of using two of the analog connectors on the breakout box with the 1010.
I thought using digital straight out of the PCI card to the console would be best. I just dont know how to do this.
Thanks
TS
Old 04-13-2013, 05:10 AM
Default Re: S/PDIF (from Delta 1010) to AES on SC48
With a bit of googling I have come across the Hosa CDL-313 which looks like it might do what I want. I just dont know enough about digital standards to know myself.
Also, I have read that just making up a phono to XLR cable with the phono outer connection going to pin 1 on the XLR and the centre rca pin going to EITHER pins 2 or 3 on the XLR.
Might this work?
Old 04-13-2013, 08:19 AM
eshop eshop is offline
See Fig. 1 on page 4 of this doc......
http://www.rane.com/pdf/ranenotes/In...S3_&_SPDIF.pdf
Old 04-13-2013, 09:54 AM
Brent Lind Brent Lind is offline
Lundahl makes a suitable transformer for S/PDIF to AES conversion, seen here:
http://www.lundahl.se/pdf/1574.pdf
K and K audio is a distributor of Lundahl transformers and also has some PCBs and such, might be a good resource for one looking to build a converter box.
EDIT: just noticed you are in Belfast, in which case K&K might not be your best option, but Lundahl is Swedish, so I'm sure you have distributor options. Sowter(UK) may also have similar units , but I can't get their webpage to load at the moment, so don't quote me on that.
Anyone using the Delta 1010? Loudnoize Ent. Pro Tools M-Powered (Mac) 1 02-13-2006 01:18 PM
Delta 1010 PCI Finchy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-15-2004 10:55 AM
delta 1010 nelsonswilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-13-2001 11:36 AM
delta 1010 nelsonswilly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-11-2001 03:58 PM
delta 1010 don't come ez Digidesign Hardware & Software 2 02-13-2001 12:53 AM
