Go Back   Avid Pro Audio Community > Live Sound > VENUE Live Sound Systems
Old 10-14-2013, 07:38 AM
Tigerspill Tigerspill is offline
Default EQing Vocals - Venue EQ or Plug-in EQ
I have always used the standard 4 band EQ (plus HPF) on an SC48. I have the plugins that came with the console a few years ago which have a couple of EQs.
Just wondering if these are better than the standard console EQ.
Just interested to learn what others do.
Thanks
Old 10-14-2013, 10:25 AM
vikingthor vikingthor is offline
Default Re: EQing Vocals - Venue EQ or Plug-in EQ
That is a good question, i normaly use only the onboard channel EQ & COMP.
that is for a few reasons; in the heat of the moment it's faster than any other plugin to get a desired sound, and i have all my other racks full of plugins, and there's no dsp left.
Though, I do think EQ III is better than the onboard one.
There's Separate selectable high-pass, low-pass, and notch filters with variable Q and slope. I guess you can give it a try
My signal flow for vocals are, Onboard channel strip, with waves C6 as insert on the input channel
and on my vocal group i use EQ III, and dynamics III or Rcomp
Sometimes Smack harmonics preset(ratio is 1:1) can be nice.
Old 10-16-2013, 12:49 AM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
Lets be honest, if you are touring with a band and would like to give them sound as good as it gets you should automate EQ's by songs or even by parts of songs. In this situation, one way to combine using both, on board and plugin EQ's is, if you automate a channel EQ song by song and then find out, that you still need to do some overall tone shaping depending on the venue. In this case I keep channel EQ automated and put an plugin up that is not included in snapshots or you could do it vice versa, up to you.
Old 10-17-2013, 08:13 AM
Thanks Guys!
Odd plug-in problem VENUE mbm1987 VENUE Live Sound Systems 3 04-02-2013 10:11 AM
Venue 3 and Plug-In Thumbnail Problem Kenmillerjr VENUE Live Sound Systems 9 08-08-2012 03:08 AM
VENUE stock plug-ins Jason Stygar VENUE Live Sound Systems 5 02-17-2011 08:40 AM
Suggested VENUE plug-ins mariobenipayo VENUE Live Sound Systems 10 08-09-2009 08:55 AM
What are some techniques for mixing/EQing vocals MusicalWonder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-19-2005 07:54 AM
