Spinning wheel in PT8 with screen redraws
Has anyone else experienced slow screen redraws in PT8 LE on the Mac.
Horizontal zooming and show/hide tracks (amongst other actions) brings up the Mac spinning wheel and takes ages if there are even a few tracks with a few regions. My previous LE setup, 7.4, dealt with more complex edits/mixes really quickly and fluently. Playing tracks is fine - no appreciable delay before play; its just the screen redraws that take ages. Any ideas? |
Re: Spinning wheel in PT8 with screen redraws
Many possible solutions for this. Have you tried trashing prefs yet?
Did you do a clean install of the OS and Pro Tools or did you upgrade over previous versions? If you upgraded - you likely will need to go back and do clean installs of both, as upgrading over old versions has been known to cause problems like this. Can you give us your system specs? |
Thanks for your advice. I have trashed preferences and repaired permissions but to no avail. I did not do a clean install of PT8. version 7.4 was already there. I will uninstall and do a clean install.
i have done a clean uninstll then a reinstall of PT but no improvement. obviously i am reluctant to do a clean install of the OS as this will wipe everything on my mac and all my network settings etc, etc.
what do you suggest? |
i have an iMac 2GHz Intel core 2 Duo
4GB RAM OSX 10.5.6 original MBOX |
the imac came with OSX 10.5 pre-installed so a clean install of the OS is presumably unnecccesary.
I have reinstalled pT on a different admin account on the imac but still really slow screen redraws. about 8 seconds to show one more track from the track list. any help anyone? |
When you updated to 10.5.5, did you use the software update panel or did you download the combo update from the Apple website? If you used the software update panel, you should try the combo update as there have been issues we've seen using the software update panel (this because it uses a 'delta' installer - looking for and replacing/adding the necessary software to update, while the combo updater installs everything.).
Also keep in mind that you can do a clean install of the OS and then transfer your user data from another system or another partition or drive on the computer. |
i updated straight from 10.5.4 to 10.5.6 using software update and them saw the digidesign advice about the combo updater and did this 2 days ago kind of on top of the previous update.
Screen Redraws? | zombie69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-25-2007 07:29 PM |
Spinning Wheel & Screen Distortion | Dennis Scott | Pro Tools TDM Systems (Mac) | 0 | 09-26-2006 12:04 PM |
Screen redraws help | Ke productions | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-01-2003 01:06 AM |
Faster screen redraws how?? | roijin | Pro Tools TDM Systems (Mac) | 2 | 08-07-2001 05:47 AM |
Slow screen redraws with quicktime | Xantar | Pro Tools TDM Systems (Mac) | 3 | 04-04-2000 04:23 PM |
