bus1&2 to external FX on 002
hi
Can anyone give me any tips on how to use bus 1&2 to external effects ? It seems to me that this has to be routed to analogue out 1&2, but PT don't let me do this, cause An1&2 goes to the master.. thanks all the best, g |
Re: bus1&2 to external FX on 002
i'm not sure if i fully understand what you're asking, but in my experience you can't directly route bus1-2 out to an external box. Busses are for use within protools.
what i do is make an aux with i/o going to the external box (maybe use Audio 7&8, that's what i use) then you can do sends on audio tracks bussed to the aux track. hope that makes sense, JE |
Unfortunately I don't think you are wrong.
Without utilizing the lightpipe i believe you are stuck with 6. Although I could be wrong... |
But what if you need to route eight send/returns to external effects (inn addition to the digital outs) ?
bus 1/2 (an 1/2) send/return can't be used because of the master out. That leaves ne with only 6 analogue send/returns (3-8) or....? please tell me I am wrong!! i need eight |
oh no!
So all the reviews of the 002 was wrong ! I can't believe this |
www.marcousticaudio.de |
I want to use send/return to external fx device through bus 1&2 routed through analogue in/out 1&2
In the reviews for the 002, I've read that is has eight send/returns - but this is as far as I can understand wrong, since analogue 1&2 has to be used for the master. |
For example, you could have the Master output to s/pdif and use external converters for monitoring. Or, you could have a lightpipe device (eg Lucid or Apogee or RME) attached and have an additional 8 channels to send and return external fx. Or monitor your Master output through this device. I hope I haven't used too much jargon for you at this stage. [img]images/icons/cool.gif[/img] There is lots of flexibility with the 002, you just need to try a few more things, read the manual, experiment and enjoy! Best regards, Haigbabe
Drive fast, take chances |
oh wait,
isn't there a separate monitor out on the back of 002 (i'm not in front of mine) that monitors all outputs? i'm confused now. je |
Why does Avid recommend external USB over external Firewire for audio drive? | DJ Hellfire | Pro Tools 10 | 10 | 03-29-2012 09:39 PM |
External dedicated external hard drive | JuanCarlos | General Discussion | 1 | 02-15-2010 03:11 PM |
Backing up Audio Drive (External) and External HD Question | JCWarrior | Pro Tools TDM Systems (Mac) | 2 | 04-13-2008 04:42 AM |
Which External HD to get? | dannyjack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-12-2008 06:48 PM |
external HD | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 05-11-2004 08:56 AM |
