Old 07-08-2019, 10:52 AM
pasanta pasanta is offline
Default Plugin window closes
After this most recent update of PT (Ultimate 2019.6.0), when I have any plugin window open, and I click the mouse anywhere else, for example to a location in the tracks window, the plugin window now closes. This didn't used to do that......I could keep plugins open, only closing them manually. It really puts a crimp in my workflow. I'm guessing this is a preference but I can't seem to find it. Any suggestions?
Old 07-08-2019, 11:18 AM
BScout BScout is offline
Default Re: Plugin window closes
Eucontrol. Eucontrol Settings > General tab > lower bottom right "Close Windows on Workstation When Exiting"
Uncheck
(or you change the Attention options in the left column so you aren't moving attention which is what closes the plugin window -- but for most the first option I've given is simplest)
Old 07-08-2019, 12:10 PM
Bingo! Thank you so much. I hadn't thought to look in Eucon.
Old 08-22-2021, 02:07 PM
RuLemer RuLemer is offline
Ah, relieved to find this thread! Thanks Eddie for the solution :)
More than plugin window at a time? DC-Choppah Tips & Tricks 4 09-20-2012 05:11 AM
Plugin separating from Plugin Window listnersupported Pro Tools HDX & HD Native Systems (Mac) 0 06-15-2012 01:29 PM
Plugin Window problems Robert Jackson Pro Tools TDM Systems (Mac) 5 02-07-2008 11:06 AM
Plugin window closes sudenly unable to recover Dan002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-13-2005 08:10 PM
Can I see more than one plugin window at once? (OS9, PT5.0) apetrocelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-11-2003 11:33 AM
