Step Input and Input Quantize..
Im a bit confused on these two functions. Do i just need to press enable input quantize, and it will work? Or di i have to highlight a region and apply it. How does this work? Does it automatically align to the grid in real time while i am playing a drum part?
Re: Step Input and Input Quantize..
I am new to protools but am learning it very quickly. I am finding that the MIDI is very different to Sonar but should work fine for me. Now for your question. I will answer with a routine that I do to make drum tracks using the quantize. First I play kick on the 1/2 note on one track. Quantize that to 1/2 notes. I then put snare on the 1/4 notes and quantize that track to the 1/4 notes. 1/8ths on the high hat and Q 1/8 etc. This will give you a tight reference track to lay down your audio or midi. All drums are on channel 10 but separated by different track numbers (so that I can mix them individually). The click feature on an aux track is a cool feature on my version 6.7. I am running winxp with sweetwater cube 3.2ghz 800fsb glyph drives 1.5 g ram. No problems here. I hope this helps
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
Input Quantize will quantize AS you record. You can quantize an existing midi track with the quantize function. I prefer to quantize after I record and sometimes will only quantize certain notes rather than make the entire track (mathematically) perfect as it doesn't sound very real.
Step input how make 1 bar step | pinnacle | macOS | 1 | 10-23-2011 05:12 PM |
Step Input Problem | jerosta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-03-2011 07:02 PM |
New to MIDI. Input is quantizing. Input Quantize is disabled | LiamSlack | MIDI | 0 | 03-25-2008 08:59 PM |
step input in LE 6.9 MIDI | steve kirk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-16-2005 09:01 AM |
record 24 tracks on one input, step by step please. | gino123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-21-2001 12:50 AM |
