Re: Serious recording bug in 6.4!!!
Hi.
I've had a 002 at home now for about 9 months and have never experienced that problem, but at work we use a HD2 currently on 6.1.2 which we use every day and we have had the same white noise problem happen 3 times in the last year....It never happened with PT 5 and OS9...To this day we still don't know why it happens... |
I've had this problem before on my powerbook, but it happened prior to 6.4 as well.
Very random infrequent bug for me. Happened maybe 2 times and it's impossible for me to get it to happen based of any particular actions. My setup: Alum 1.25 15" Mbox PTLE 6.4 512MB RAM external 7200 firewire audio drive OS 10.3x (latest) hope this is helpful. I've generally found the Mbox to have some annoying qualities that are probably attributable to USB. I get lots of errors saying it can't keep up with audio etc. etc. Also, phantom power can't be toggled while PTLE is open. Have to reboot. |
Markus,
Can you tell me more about the nature of your session. Does this happen randomly on all types of input sources, or only when you're recording through AmpliTube? What kind of drives are using, and how they connected? Do you have anything like Norton file saver installed on your system. Did you make all of the energy saver settings suggested in getting started guide? Does this happen as you're working or does it occur if you take a break for a few minutes and then come back to record. Let me know a little bit more about your system and what you're up to when this is happening so we can take a closer look at it. Thanks Digidesign Tech Support |
Are you running cracked plug-ins?
Hi there!
1. Guitar to Mic/line 1 of the 002 onto an audiotrack with amplitube as insert effect. Even removing the plug didn´t help. The session was about 6 audiotracks with one BF76 and this amplitube and no editing or automation. 2. Sampltetank as insert on an audiotrack and recording the output to the track. I couldn´t remove the plug of course, otherwise I wouldn´t had no inputsignal. The session was very similar: About 8 audiotracks, no other plugs, no editing or automation. Quote:
G4 Dual 1,25 GHz 1 GB RAM 2 hds (every disc wtih 80 GB) ATI Radeon 9000 Pro IOMEGA ZIP 100 (usb) Superdrive Combodrive OS X 3.2 DIGI 002 with version 6.4 running Hope, that helps. Greets Markus
www.marcousticaudio.de |
#16
Any Waves plugs?
"I'm one of the few people I know who knows the few people I know" - CL |
#17
Greets Markus PS ... and for Tito: there are NO cracked plugs installed!!!
#18
Well you might as well make sure you have waveshell 4.01_x in your digiplugins folder. That's what done it for me in the past.
C
#19
Greets Markus
#20
Not sure this will help or make things move forward but I had a similar bug some days ago.
In my case, trouble came with an imported audio file (personnal soundbank located on an external Firewire drive). I listened to that sound in the Import Window, everything seemed fine. I imported it and then, though the waveform was displaying a sound lasting, let's say, 12 seconds, the last two seconds of the file didn't make a noise... I tried to play that particular part... Nothing... I then tried to delete and re-drag from the region bin, same thing. Tried to ctrl+scroll the sound, nothing. Tried to play it from the region bin, nope. I finally decided to consolidate and, as a matter fact, the end of the region became all flat... Pretty weird. That's definitely the first time I've experienced something like that in PT. BTW: talking of bugs, you english and americans probably don't care, but illegal characters have become a drag! Error 9035 all over the place for many users I know. This used to be the case in previous versions when the Mac-PC compatibility option had been checked but it's now happening in "normal" sessions (where the option has not been checked at all). Pretty annoying... Specialy for us French who use a lot of accents (éŕčŰ....). Why is that?... No one knows... And it only seems to appear when a file's name has at least 2 or 3 of those characters. Doesn't seem to happen with just one...
Some music?... http://tmweb.free.fr |
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
low latency recording vs low hardware buffer size recording | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-27-2009 06:49 AM |
Distortion of Recording When Playing Back Recording | acs | Pro Tools M-Powered (Win) | 2 | 03-18-2008 04:29 PM |
PT 5.1 - Recording very lengthy narrative project.. ran out of recording disk space? | Rockman-Songwriter | Pro Tools TDM Systems (Mac) | 6 | 04-16-2003 12:32 AM |
Recording automation AT THE SAME TIME as recording tracks | mikeb37 | Tips & Tricks | 3 | 03-13-2000 09:43 PM |
