#21
Re: macOS Sierra - Compatible Plug-ins & VI's
#22
Yep, we organise a community driven overview of compatibility issues here:
https://docs.google.com/spreadsheets...F0q_z0/pubhtml |
#23
Is anyone else having very erratic option+scroll behavior? normally option+vertical-scroll should zoom in/out on the timeline, and option+horizontal-scroll should zoom waveforms. But since I installed Sierra, now any option scrolling does both, and has also randomly opened the task manager window twice.
Sierra 10.12, PT 12.5.2.
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
#24
Source Elements .., Nexus Basic & Source Connect ETC
Word from SE support is reporting , "Just wanted to let you know that we have tested Source-Nexus Basic on macOS Sierra and have found it to be fully functional, including the AAX plugin in Pro Tools 12, and the VST and AU plugins in Reaper. In regards to the Source-Connect issue mentioned in the Avid forum, we have confirmed that there is a startup issue, but if you continue past the prompt, the software is still fully functional as well. We will be looking into this issue more. Please note that this only seems to be affecting Source-Connect Standard (Pro and Pro X versions are unaffected). The latest versions of the rest of our products are also running fine on macOS Sierra. Thank you for bringing that to our attention."
Pro Tools 2021.6.0 Native * Slate Raven MTi-1 Version 3.9.1 * AVID MBox3 Pro * OSX Mojave 10.14.6 * MAC PRO (late 2013) * 3.0 GHz 10-Core Intel Xeon E5 * 64 GB Ram 1866 MHz DDR * AMD FirePro D700 6GB * Lacie LBD 1TB Thunderbolt 2 PCiE * Blackmagic Multidock Thunderbolt2 * Samsung SSD's 850 Pro * WD Black HDD's |
#25
I will copy the link to the Opening Post to make it easy for everyone to find . Just a question , is it possible to ADD plugin manufactures to that list - how does one do that task with the speadsheet ?
#26
Word from McDSP is : Sierra is not yet officially supported.
- No ETA on Sierra at this time.
#27
FOCUSRITE : ..., Are they Sierra ready ? ..., Mostly YES (read link below)
https://support.focusrite.com/hc/en-...l&utm_content=
#28
Just curious... Has anyone tried Sierra and 12.6?
I did, and surprisingly, it didn't work. 12.5.2 on ElCapitan has a horrible graphic glitch which renders metering with some Avid plugins worthless, but 12.5.2 on Sierra fixes that problem and seems to work fine. 12.6 on the other hand seems purposely crippled. I can't select HDX as a Playback Engine... it just doesn't show up. Past that huge stumbling block 12.6 worked fine for the 2 minutes I used it... before I went back to 12.5.2. |
#29
Do you have the i/o DigiLink license on your ilok ? otherwise it won't see the HD interfaces or any third party HD interface connected. It's a separate license needed for HDN/HDX setups
PT on macOS Sierra? | eesn | Pro Tools 12 | 66 | 10-01-2016 11:46 PM |
macOS Sierra 10.12 not yet supported | Avid | Technical Alerts | 0 | 09-20-2016 10:34 AM |
macOS Sierra official release date is Sept. 20. How long til Pro Tools is compatible? | Justin1524 | Pro Tools 12 | 29 | 09-11-2016 04:36 PM |
