Pro Tools Installation via Avid Link or manually?
Hello,
I'm setting up a new Pro Tools Studio Installation on a fresh system, the question is, should I use Avid Link to download and install Pro Tools or the manual file download installation, which is more reliable? Also, should I right click install as an administrator, the setup file? Last edited by atticmike; 06-16-2023 at 01:43 PM. |
Re: Pro Tools Installation via Avid Link or manually?
It is not installing per-se that is an issue with Avid Link. It still invokes the standard installer, it's more all the stuff about downloading the installers, correctly working out if installed software needs to be updated, etc.
Like many users I have no time for buggy unreliable Avid Link, it's been demonstrated too many times to be buggy. It's sadly just badly done. Uninstall it, you are better off manually managing your system. And that's true for many plugin managers, ... Softube's one is broken on macOS for example, and then you get stuff like Toontrack Product Manager that just seems very well done. No need to run the install as Admin. You should be an Administrator on the computer. Everything you need to know is documented: e.g. https://avid.secure.force.com/pkb/ar...s-Installation Last edited by Darryl Ramm; 06-16-2023 at 03:50 PM. |
I've been using Link to update PT and plugins for the last year or so without issue. I think the first few versions tarnished folks opinion of it.
The only problem I'm having is it says I have 2 products to update, but everything is updated. Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Pro Tools Intro doesn't show Avid Link | joaoteodosio | Getting Started | 2 | 04-11-2023 09:32 AM |
Avid Link activation error pro tools intro | alriqa | Pro Tools | 2 | 03-21-2023 11:05 AM |
Avid Link Download Errors for Avid Link 2022.9 and Pro Tools 2022.9 | cmhawke | Pro Tools | 11 | 03-08-2023 02:45 AM |
Avid link pro tools v 12.5.00 | fredmarzin | Pro Tools | 3 | 07-21-2022 12:00 AM |
Avid Link - Pro Tools Feature Requests - Lounge | simonchase | Pro Tools 2018 | 4 | 01-18-2019 04:13 AM |
