Need Help! Popping and Crackling Sounds!!
Tried bouncing down from a Fostex VF-16 yesterday via the ADAT lightpipe and for the most part the sound comes through sweet and clear. Then suddenly it will start popping and crackling and not just on one track but across several tracks at different points in the songs. Sometimes the cracks and pops are quite loud and cause the track to peak. Am I doing something wrong or is there something I should be aware of?
Help would be appreciated. Many thanks, Chris LoA |
Re: Need Help! Popping and Crackling Sounds!!
Are you referenced to the Lightpipe optical?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
hey..your problem w/ the clicks is that the ADAT and PRTOOLS session are set to different sample rates..if you already recorded onto the adat at 44.1- your seesio has to be in that sample rate. if you are just using the adat as a digital 8 channel convertor- change the adat to the same sample rate as your PT session..your problems will go away !!
LE 8.0.4 phantom popping, crackling. | 809578998 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-29-2011 08:33 PM |
Random Crackling and Popping on playback..MBox | RC99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 02-27-2007 03:15 PM |
Popping and Crackling with Digimax LT | Digitalkidd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-13-2004 08:58 PM |
Popping and crackling | sinnagod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2004 07:03 PM |
Once again: popping and crackling on a AMIII | Jitter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-06-2001 04:30 PM |
