Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-06-2020, 06:27 PM
wwittman wwittman is offline
Default MIDI Editor not loading
I’m just finding the MIDI Editor page isn’t showing any MIDI info at all
Anyone else having issues ??
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 05-07-2020, 02:40 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Re: MIDI Editor not loading
Works well here.
The annoying thing I noticed is that double-clicking on a midi clip (which should open the midi editor) only presents you with a tiny inconspicuous minimized box at the top left of the mix window that you have to manually open. This minimized window is so tiny/inconspicuous/unexpected that it took me a while to understand what was happening.
That wasn't happening in 12.8.1 which I was running before moving on to 2019. Bring-to-front doesn't work, because it is in front, only minimized. I haven't checked if this is random, but this seems to happen in new sessions; after a while double-clicking starts to open the midi edit window directly, as it should.
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 05-07-2020, 03:26 AM
JFreak's Avatar
JFreak JFreak is offline
What system config is causing you trouble? Didn't mention which OS or hardware, but assuming you are using PT 2020.3 because posted on this folder...
Janne
Old 05-07-2020, 10:51 AM
Weird
I’m running 2020.3 in Sierra in an iMac i7
It opens the MIDI Editor window but there’s no MIDI info shown at all
(Even though the track plays and ‘works’) etc. )
William Wittman
Producer/Engineer
Old 05-07-2020, 10:55 AM
JFreak's Avatar
Sierra is not supported any longer. Compatibility info here.
Janne
Old 05-07-2020, 10:07 PM
I know.
William Wittman
Producer/Engineer
Old 05-08-2020, 12:32 AM
JFreak's Avatar
Well then, isn't it kind of obvious your problem might be related to unsupported configuration?
Janne
Old 05-08-2020, 03:38 AM
Sardi Sardi is online now
Weird
Hey William,
I installed 2020.3 on my Sierra partition to test it for you. MIDI editor opens and notes are visible. Nothing out of the ordinary. Whilst it may not be a supported configuration, I don't think that's your problem.
Does this happen with existing sessions or also new ones? The below image was with a freshly created session in 2020.3. Would be interesting to see if you've tested it with a new session or just a pre existing session that may have been created in an older version of Pro Tools.
Old 05-09-2020, 09:19 PM
thanks,
yes, I didn't think it would have to do with the OS either... and it was happening with all sessions, whether new or not.
I (reluctantly) did a reinstall of 2020.3 and that seems to have fixed it.
William Wittman
Producer/Engineer
MIDI Editor and MIDI Event Editor keyboard commands broken 12.4 HD Marsdy Pro Tools 12 5 01-31-2016 05:01 AM
Noob question regarding loading shows created on the offline editor - help Riquier VENUE Live Sound Systems 3 07-12-2015 02:41 PM
11 rack editor not loading controls for effects/amps/mod/delay etc - see image rbc1 Eleven Rack 5 10-06-2014 10:14 AM
11R editor vs Pro Tools - not loading ERXP sighermike Eleven Rack 13 09-16-2014 04:40 PM
Calling all that write/program midi drums by hand in the Pro Tools midi editor. Mikey Ace Virtual Instruments 2 10-05-2008 07:14 PM
