Old 08-12-2015, 12:52 PM
goodhertz's Avatar
goodhertz goodhertz is offline
Goodhertz
Default Goodhertz releases Tiltshift — superior tone-shaping EQ plugin
— 15-Day Free Trial Available —
Tiltshift is a new type of tilt EQ that does more with less. More than any other equalizer, Tiltshift is able to dramatically alter the tone and timbre of your audio — going from mellow warmth to crystal clear with a single, loudness-matched slider — while sticking to the first rule of mastering: do no harm.
By using extremely gentle slopes (often less than 1 dB per octave), the relative phase, frequency, and transient response of the audio is preserved, making it faster and easier to find the right global EQ curve before focusing on specifics, and Tiltshift’s perceptual loudness lock technology makes it easier to compare EQ settings, or automate the tilt, without worrying about gain changes.
TILT FEATURES
  • Incredible-sounding tilt algorithm
  • Variable tilt frequency range
  • “Perceptual loudness lock” for perfectly matched loudness
  • Completely automatable
  • CPU-friendly enough to be used on every channel
FILTER FEATURES
  • Independent high/low cut filters
  • Variable filter slope (from 6 to 48 dB/Oct & anything in-between)
  • Independently controlled resonance
  • “Listen” function to audition what you’re filtering out
  • Fully sweepable
Tiltshift is available on the Goodhertz store for 64 bit AU/AAX (Mac)
HTML code is On
Goodhertz Panpot — a new panning plugin that will change how you think about stereo goodhertz AAX Plug-ins 18 04-18-2015 07:35 PM
UA releases AMS RMX16 Reverb plugin nst7 AAX Plug-ins 13 09-22-2014 07:53 PM
Manny Marroquin Tone Shaper Plugin $50 skipdog Buy & Sell 0 04-11-2014 08:24 AM
room tone extract and generate plugin Guruman Post - Surround - Video 12 04-20-2007 07:05 AM
PSP releases Lexicon plugin for RTAS finally! jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-16-2003 11:37 AM
